10-08-2012, 02:43 AM | #1 |
can somebody identify this engine?
Hi, my friend found a engine for my proyect car, but the engine is on an old oldsmobile car, to me the engine look like a gm 307 engine, not oldsmobile engine, can somebody confirm me this ?
------------------------------------ 1988 Ford taurus LX SW V6 3.0L vulcan - Axod 1973 GMC Jimmy Sierra 4x4 L6 diesel nissan LD28 (temporal engine) |
10-08-2012, 07:31 AM | #2 |
Re: can somebody identify this engine?
Can you use a mirror and flashlight to read the block casting number? It's on the back ledge where it bolts to the tranny, driver's side.
10-08-2012, 09:01 AM | #3 |
looks like a real old OLDS. When they were new they were OLD.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-08-2012, 01:07 PM | #4 |
look on the front of the motor by where oil fill tube is you see a lil plate with some numbers and letters if you look them up you will figure out what motor it is and lookin at the pics it is an oldsmobile
10-08-2012, 05:28 PM | #5 |
It's a very old Oldsmobile engine. It looks like one from the 1960's.
68 4wd Stepside 69 2wd Stepside Project 71 2wd Blazer Project 72 2wd 3/4 Ton Project or Parts? 73 4wd Blazer |
10-08-2012, 05:46 PM | #6 |
It is an old's engine. Being that it is in a Chevy truck I would guess that the original engine was a 350 diesel. The 350 old's gas engine was a easy bolt in swap.
Scott 66 chevy short step 327 4speed 67 chevy Short Fleet tpi 350 700r4 72 chevy K10 swb 01 GMC Sierra 01 Pontiac Bonneville |
10-09-2012, 08:29 AM | #7 |
I would say from the looks of it probably Buick/Olds/Pontiac. Check the bellhousing pattern and get some casting numbers for us. If you get the numbers off the heads too it will help. There are websites you can find using google search to check and find out exactly what it came out of if you get the engine stamping off the deck pad too. It will tell you what car it came in with auto or manual trans and what HP rating from the factory. It looks like it could very well be an olds 350
1970 Chevelle SS396 1984 K5 Blazer -First Truck! 1999 Big Block K2500 'Burb |
10-09-2012, 03:56 PM | #8 |
Slots go on anything!
The really wide intake, front oil fill, and valve cover pattern identify it as an olds engine. From there, it is hard to tell.
1974 Jimmy- 5.3/4L80e/NP241 |
