Old 10-08-2012, 03:57 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
wanted....affordable, working under dash a/c/heat
Going to need a/c in my shop truck if I'm going to drive it come this summer...
I can get a brand new setup around 700 at a show (complete with compressor and condenser)....trying to see what I can find on here....gm unit or aftermarket....with or without compressor/condenser but prefer complete. Also would consider trading a 100% complete stock a/c setup for an aftermarket setup...I don't want the bulkiness of the stock box....plan to shave my firewall...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-09-2012, 01:49 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: wanted....affordable, working under dash a/c/heat
Gm dealer ad on, old air products, etc all considered....have plenty of time to find a deal before sumer
Old 10-15-2012, 06:37 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
ttt
Old 10-15-2012, 08:07 PM   #4
100%Chevy
I pulled the underdash unit from my 68 about 2 years ago.Never tried to make it work,although it was sealed at the time.
Has a York pump with the small block engine brackets for the passenger side.
Will need an expansion valve if you don't want to use R-12.And new hoses.
I also have the near perfect heat only parts and controls from the same truck.
Truck has 59,000 original miles.
Shipping would be a lot!
Make me an offer.
Mike.
100%Chevy is offline   Reply With Quote
Old 10-15-2012, 08:14 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
Any pictures? If you can box it up and measure/weigh the boxes I could send a label for fedex to pick it up from you.
Old 10-15-2012, 08:32 PM   #6
100%Chevy
I'll try to find some pictures of some of it.
Means I got to look thru a lot of pictures!Might take a while!
I'm putting the factory system in mine.Got the under hood done-need to do the dash.
Do you have a near perfect a/c control unit?
Mike.
Old 10-15-2012, 08:33 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
yes, I have a very nice original....also have an NOS GM one new in box
Old 10-15-2012, 09:23 PM   #8
100%Chevy
I have some pictures in my picturetrail,but can'tseem to log-in!
Maybe if you try this link,it will come up for you.
Look in album 1.68 annivarsary special.
http://www.picturetrail.com/100chevy
Mike.
Old 10-15-2012, 09:29 PM   #9
BMERDOC
BMERDOC's Avatar
FWIW, if you can, find something compatible with R134A. Isn't much problem converting but...just saying.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-15-2012, 09:40 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Mike.
thanks, that compressor is huge so I'm going to pass.
As I research these more....I am leaning towards one that incorporates defrost also or a complete aftermarket a/c setup like vintage air/old air if I find a deal
Old 10-15-2012, 09:41 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
definitely will
Old 10-16-2012, 02:35 AM   #12
jorgensensc
jorgensensc's Avatar
Hey there,
I have an underdash system that I bought from a board member awhile back, but sold the '68 it was going in. I was told it was working and it looks like it should work without a problem. It has pretty nice woodgrain on it. If your interested i could do 100.00 plus shipping (what I paid if I remember correctly). No compressor, just the underdash unit. Let me know if your interested.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
