Old 05-29-2003, 07:07 PM   #1
68 Suburban
68 Suburban's Avatar
Fan Belt Routing with A/C
Ok, I am adding my aftermarket A/C and I am wondering what is the correct routing of the belts. Right now I have a 2 grove pully.
On has a belt for the powersteering pump to the lower crank pully.
The other has a belt from the crank pully, to the water pump pully, to the alternator drivers side.
Now with the addition of the of the A/C on the passengers side. how should I run the belts.
Pictures would be great if anyone has them.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-29-2003, 07:34 PM   #2
cdowns
cdowns's Avatar
the factory a/c uses a 3groove crank pulley , furthest foward is the power steering the middle is a'c the one closest to the block is the alt
Old 05-29-2003, 09:42 PM   #3
68 Suburban
Thanks, I do have a 3 grove pully I will use.
