10-08-2012, 08:42 PM | #1 |
Floor pan mod needed?
I'm still a newby to this model truck and have several questions. I've used the search button, so please bare with me.
I have a 68 swb fleet with a factory 6 cyl with 3 on the tree. I'm installing a 454 with a muncie 4 speed in the floor. Will I need to modify the floor pan? Will I have to install a "high hump" floor pan? If I need any modifications, where do I purchase? |
10-09-2012, 06:05 PM | #2 |
Re: Floor pan mod needed?
No advice from anyone? I will have to test and trial I guess.
10-09-2012, 07:16 PM | #3 |
motor exploder
I don't have any experience with a BB & muncie trans, but I did install a 454 with a muncie '631' bellhousing on a TKO 500 and it BARELY cleared after a little persuasion with a shop hammer on the body seam/lip that runs on the inside of the trans tunnel on the low humps. I have since put a high hump in since I'm doing a frame off, but I had the combo in the low hump and drove it that way for 2 years with no problems. hope this helps.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-09-2012, 07:39 PM | #4 | |
The 454 engine and bell housing will fit without any problems but I'm not sure about the muncie 4 speed. I used a BB and a turbo 400 on my 67 "low hump" which came from the factory with a straight six and three on the tree. The trans should fit in a your floor but you will still need to mod for the shifter. |
10-09-2012, 07:40 PM | #5 | |
10-09-2012, 08:11 PM | #6 |
Only mod for the trans will be the hole in the hump for the shifter. (low hump will work).
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
10-09-2012, 08:24 PM | #7 |
10-09-2012, 09:08 PM | #8 |
10-09-2012, 09:22 PM | #9 |
Man, wish I could trade you. Unfortunately, mine is made into the floor pan. It doesn't unbolt, so to speak. Thanks for the offer though.
10-10-2012, 04:06 PM | #10 |
On the muncie 4 speed, the shifter mounts to the side of the trans. The hump height shouldnt effect your shifter length-- I think maybe seat height and your arms reach may have more to do with shifter height requirements more than anything. One other thing as an after thought---if you are using a bench seat--it May necessitate some creative bending of your shifter handle.
10-10-2012, 08:56 PM | #11 | |
10-11-2012, 09:54 PM | #12 |
Remember,,, "If Mamma aint happy----aint nobody happy!!!"
10-11-2012, 11:32 PM | #13 |
That is very true.....
10-11-2012, 11:39 PM | #14 |
I have the cut out from my floor where I put in a high hump if you want it. It is just sitting in the scrap pile, you would have to weld it in assuming there is enough of mine to fill what you need.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
10-11-2012, 11:45 PM | #15 |
Are we talking an M20,21,22 Muncie 4 speed or those SM*#%? 4 speeds? The M20-22 are the same exterior size as a 3ott trans so there would be plenty of room. if you are going from a 6 to an 8 you will need the proper motor mount stands moved to the correct location (forward one hole)and then if so equipped the trans bellhousing xmember will need to move forward one hole as well. Either way on the trans and BB I have seen several install MT/BB without floor mods.
10-11-2012, 11:58 PM | #16 |
Not sure if it's a M20-21-22. The truck currently has a 327 with a 3 speed manual transmission. "Three on the tree". I think the mounts will work.?.? Have to investigate that.
10-12-2012, 12:17 AM | #17 |
Motor mount stands are different for I6, SBC, BBC. You will need BBC mounts for the engine and installed in the proper frame hole. Here are some pics of trans, M20-22 Muncie., 3OTT Saginaw, and Muncie SM465. Which does your 4 spd look like? The last pic probably (SM465 Muncie) needs a high hump tunnel. I have a high hump for my truck but I needed it because I have a 4L60E that was way to close to the floor (couldnt get the trans mount in without rubbing the cab floor).
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 10-12-2012 at 12:19 AM. Reason: spelling |
10-12-2012, 12:20 AM | #18 |
Had no idea there was a difference between sbc and bbc mount stands. That's good to know.
My transmission looks like the first picure. Except not as clean. |
10-12-2012, 12:47 AM | #19 |
That trans will fit fine under the stock low floor, no mods needed other than a hole for the shifter. I was going to run one of those but changed plans. I could not find any shifters for a truck but was looking at a shifter for a 55-57 chevy (car) bench seat that had the longer handle. either way buy a shifter and they (B&M or others etc) offer different length shifter handles.
Here is a link about the different motor mount stands, take a look. You can find the BBC stands in the classifieds on here all the time. http://67-72chevytrucks.com/vboard/s...d.php?t=437680 If you were to remove your 6cyl engine stands you will notice there are 3 evenly spaced holes on the top of the frame. A 6cyl goes in the rear 2 holes and an SBC or BBC goes in the front 2 holes. if you look at yours with the 6 installed there is a hole in front of your mount stands. this wiil be the new front mount hole for a V8. You can use the current mounting and drill the crossmember for BBC stands but you will have a heck of a time working on you dist but then again it does help with weight distribution with the engine in the rear location.
10-12-2012, 12:50 AM | #20 |
If your 3OTT has a bell housing mount Xmember (cast iron) you will need to also move it forward one hole. You could also use a Camaro aluminum bell and remove the bell Xmember and use a tail trans mount Xmember which would be a better choice anyway with the BBC torque.
10-12-2012, 12:52 AM | #21 |
Get the numbers off of your Muncie trans and let us know what they are and we can help ID it for you. I will check back tomorrow. Good night!
10-12-2012, 10:31 AM | #22 |
Thanks rustbuket. Tons of helpful information coming from you. I really appreciate you taking the time to clue me in. I'll get the transmission numbers and report back.
10-12-2012, 10:34 AM | #23 | |
10-12-2012, 11:34 PM | #24 | |
http://www.5speeds.com/muncie.htm There are a few differences such as the input shaft spline count, shaft diameter, tail housing length for BOP cars, support shaft bearing size (some fit in iron 3ott bell housings some dont) Ratios etc etc.
10-12-2012, 11:36 PM | #25 |
No problem, this is what the forum is for! sharing good info and bad mistakes. I have some of both
