Nos 71-72 ball joints, tie rods 1/2 ton disc
For Sale
New Old Stock Ball Joints for 71-72 1/2 ton with Disc Brakes #3997409 $20 ea plus shipping. I have 8 total Includes all Hardware New Old Stock Tie Rod Ends for 71-72 1/2 ton with Disc Brakes $15 ea plus shipping. These do not include the castle nut or pin |
![]() Join Date: Sep 2002
Re: Nos 71-72 ball joints, tie rods 1/2 ton disc
Interested on a set of upper & lower ball joints if available
also do u have inner & outer ends? Need both Thanks Posted via Mobile Device
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
ok, lmk what 2 of each will run shipped to 08753
thanks
I'll take one ball joint pending shipped cost to 32803, commercial address. That looks like an upper ball joint.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
![]() Join Date: Mar 2011
Scott if it makes cent$ can i hitch a ride and get 2 also put 4 in one box split the ship if it makes cent$ if MoreLove will do it ....LMK
Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
If I ship 4, shipping looks like it would be $18. Just let me know what you guys want to do. Not much savings to do one box over two. I would do 25 ea shipped if you buy two or more
#9 | |
ill take 2 to 07981 for 50. shipped send me the paypall info thank you Jess
![]() Join Date: Apr 2011
All take two of the lower ball joints.
![]() Join Date: May 2005
how many ball joints do you have available?
i'll take 2, maybe 4 if a friend decides he wants a pair. -jake
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
I'll just take the 2 ball joints shipped for $50.
Pls lmk payment info. Thanks Scott
#13 |
OK, I'll take one. Is a money order ok?
#14 | |
Thanks Russell
Russell |
#15 |
Not sure if upper and lower joints are the same and from what Im finding the part number I have is the lower joint. If the number I have is what you are looking for, 2 ball joints and 2 tie rod ends shipped would be $80
#16 |
OK guys we have a problem. I have 8 ball joints and request for 9 possibly 11. Also, if it helps, I do have one more ball joint that I did not list. It does not have a number on it but the #3997409 joint is on the right in the pic which I believe to be lower and the one on the left Im not sure what it goes to.
ZICC1835 REEDS72 BIGJAKE97 SCOTTH You guys said "Ill Take" first but FL71C10 said it first pending shipping but confirmed later than the other 4. Im lost now as to who gets what. BigJake would you take one if FL71 wants one for sure since you were last in? |
#17 |
I think all pass on the ball joints thay look to be uper and I need lower thanks.
#18 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Is there any way to verify this before you sell these?
#19 |
![]() Join Date: Feb 2001
MoreLoveThanMoney...
You might want to double check these parts for verification. I have sold some parts and I descibed them wrong... I got everything straightened out but the process of reshipping the parts back and forth was a pain in the but. Best of luck. ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#20 |
I have tried to verify whether they are upper or lower but I do not have anything to go off of other than the part number on the box. When I google the number everything I find says lower. I have never changed ball joints on one of these trucks so I don't have any personal experience with the difference between upper and lower. I just had a box of NOS parts that weren't doing me any good on the shelf so I was just trying to get these parts available to guys that can use them. I wish I had more info to be more accurate. I'm open to suggestions of a verification process of somebody has one.
Posted via Mobile Device |
#21 | |
If you have a part and are not sure what it is...post a picture in the 67-72 Message Forum and ask... I bet you will get the answers you seek. Best of luck.
#22 |
Maybe this will help. Tried to show center to center on mounting holes.
#23 |
I have 6 of these left at this time. ZICC1835 has purchased 2
#24 |
They are definitely UPPER ball joints.
Lower ball joints press in. The upper ball joints bolt in.
#25 |
I'll just pass on the one.
