Old 10-08-2012, 09:16 PM   #1
DMViergever
Replacing rocker panels
I'm replacing the rockers on my 51 and I got the drivers side off and have the new one held in place. It measures out good, fits just like the passengers side and falls in line perfect. I'm just curious if I need to weld it up and run with it or tack it and mount doors...any advice is appreciated.
DMViergever is offline   Reply With Quote
Old 10-08-2012, 10:38 PM   #2
chev3600
chev3600's Avatar
Re: Replacing rocker panels
You know you want to check it with the doors on, or you wouldn't be asking right? You'll be happier knowing it fits as good as it can.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 10-08-2012, 11:02 PM   #3
DMViergever
It more just seemed right? Are there any panels that rockers can effect the fit of?
Old 10-09-2012, 07:31 AM   #4
chev3600
chev3600's Avatar
As long as the door opening is still in the same place, it really should be fine, but original fit wasn't great anyway. Only thing that would remotely change is the gap from the bottom of the door to the rocker. The Chinese stamped metal isn't always (ever) identical to the original. Chances are you're fine.
