Ok so.. Im replacing the shocks/springs in my truck. I got the old rear shocks/springs out and at the top of the rear springs, the retaining cup was rusted out and some of the panel that the cup attaches to is also rusted. Can this part be replaced or re-welded in? What have yall done when faced with this problem?
Pic here: ![]()
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 ![]() |
Re: Rear Spring swap - HELP!
two more pics:
PASSENGER SIDE: ![]() DRIVER SIDE: (worse) ![]()
![]() Join Date: May 2012
i have not seen one that bad...i would guess that someone makes replacement parts for what you will need. maybe some one from up north has seen this and can tell you for sure what has to be done..good luck on your build....
Im guessing I can drill the rivets out of the old plates/mounting pad/whatever its called and just weld/bolt new plates in their place? anyone got any pics/links who has done this before?
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 ![]() Last edited by dmw319; 10-08-2012 at 10:44 PM. |
I've seen guys parting trucks on the forum sell those parts to guys that wanted to bolt them in, so I think you should be good taking the old ones out and just bolting up some new ones. Check out the threads in the parts board and I'm sure you'll find someone that can get you those pieces.
Mine aren't as bad as yours but they're getting there so I'll be doing the same thing before too long.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
#6 | |
Could I replace the entire rear crossmember that the springs/struts attach to?
Will this one work?? http://www.ebay.com/itm/NEW-Rear-Sho...-/380460183316
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 ![]() Last edited by dmw319; 10-09-2012 at 12:09 PM. |
anyone?
Looks like you have some frame damage from the rust you are going to have to repair while you are at it. Definitely hit up the parts board. If you don't see it listed, ask someone who is parting out a truck.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
![]() Join Date: Mar 2009
my 69 was in bad shape in the same area, I've gotten frame pieces to repair mine but wanted to tow a load with it. welding in the pieces and fishplateing them also. luckily I found a new frame and am in the process of swapping the frame.
did you keep the frame pieces that you were going to weld in? im gunna need some to weld in.. i might just see if i can find some rectangular sheets of metal to weld in though.. hmm..
Charlie Daniels w/ a Tq Wrench
I have those pieces you asked about, look back in the 71 parting out thread. They have surface rust, but it is minor, no rust scaling or holes. Just grind the rest of the rivets out and bolt them on.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
#13 |
Anyone know the best place to buy some plates that I can weld in to the frame? Something similar structure/thickness to the size of the frame if not bigger/beefier? I will need to repair some of the frame and trying to find some metal!
#14 |
I do have the pieces and the crossmember on hand. Pm me with your information and I'll get a quote for shipping sorry I didn't see your response before tonight.
#15 |
I've got the crossmember and brackets but the frame where they connect to is rusted also. So I need some basic welding metal to repair it.
