10-09-2012, 12:40 AM | #1 |
Need pic of tach wire through firewall
Does anybody have a picture of the correct location of where the tachometer wire should come through the firewall? Mine comes out with the speedo cable I'm sure this is not right. Thanks
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
10-09-2012, 01:32 AM | #2 |
70+ ( Old Skool Club )
Re: Need pic of tach wire through firewall
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-09-2012, 07:48 AM | #3 |
67-72 parts collector,…
I think 72BlckButy had a thread on this.
I'll look.
10-09-2012, 07:51 AM | #4 |
This is where Nate drilled the hole on his '69.
Were there different locations for different year trucks?
10-09-2012, 01:19 PM | #5 |
The Assembly Manual shows different routings (I think two) for the wire depending on the year. The location above appears correct for 72. As I recall (don't have the manual here) it shows the wire passing through one of the grommets near the distributor for at least the 69s and earlier. I think it's the grommet the oil gauge line passes through.
If someone has other definitive info regarding the original factory routing for the 69s I'd be very interested. |
10-09-2012, 05:45 PM | #6 |
I just drilled one today, the above pic is correct. I checked a 72 GMC W/tach before I drilled
10-09-2012, 05:59 PM | #7 |
Wide n'Low
This might show the early cab style, not 100% sure
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
10-09-2012, 07:37 PM | #8 |
Subscribed.
Posted via Mobile Device |
10-09-2012, 11:22 PM | #9 |
does anyone know where the whole is on a 67 68 cab?
10-10-2012, 12:00 AM | #10 | |
10-10-2012, 12:50 AM | #11 |
As I noted above in post 5, the Assembly Manual shows it going through an existing grommet (I think the one the oil line goes through) for the 69s and, I believe, the 67s and 68s as well. I don't have the assembly manual with me, but I can double check in a couple days and post that info.
It would be great if owners of 69 and earlier trucks equipped with tachs from the factory could confirm if this is what was actually done. I plan to put a tach dash in my 69 and would like to know also. |
10-22-2016, 05:15 AM | #12 |
good info. how about a vacuum line?
