Old 10-09-2012, 08:07 AM   #1
focusedontheprize
focusedontheprize's Avatar
Mounting clutch master cylinder on frame
I have a 5ML60 (NV3500) transmission I am putting in my '49. With this transmission I need to run a hydraulic clutch. My goal is run a clean firewall with nothing on it, so the master cylinder I would like to run on the frame.
The truck frame and suspension is stock. I do have the CPP Disc Brake kit on it with the brake master cylinder being mounted on the frame. So space is a little tight.
I saw this over at Custom Classic Truck and was thinking I could re-create this setup for my '49 Chevy.
How else have others handled a clutch master cylinder reservoir? Do you guys all run them on the firewall if anything?
focusedontheprize is offline   Reply With Quote
Old 10-09-2012, 11:55 AM   #2
mr48chev
mr48chev's Avatar
Re: Mounting clutch master cylinder on frame
I haven't had the need yet but that looks like it or something similar would fill the bill.
Old 10-09-2012, 03:10 PM   #3
solidaxel
solidaxel's Avatar
Two of the fleet of AD's are standard clutch cars and i am using the stock peddel assembly and cast iron bell housings, the 55 has a Tremec TKO and the "strech" has a Saginaw 4 speed.
I wanted to keep the firewall clean as I filled all the holes
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-09-2012, 03:12 PM   #4
focusedontheprize
Where did you mount the hydraulic clutch reservoir and master cylinder?
Old 10-09-2012, 03:21 PM   #5
solidaxel
solidaxel's Avatar
I guess I should have spent more time reading your post.......HYDRAULIC,
Both mine are manual, sorry
LS 3 4L70E
Old 10-09-2012, 03:43 PM   #6
focusedontheprize
Ha no problem at all.
Old 10-09-2012, 03:48 PM   #7
solidaxel
solidaxel's Avatar
Take a look at ECIHot rod brakes
LS 3 4L70E
Old 10-10-2012, 08:16 AM   #8
focusedontheprize
Will do.
