Vapor Barrier anyone?
Did my '68 come with any kind of vapor barrier behind the door panel to keep moisture out of the cab? I know these are "wet" doors and so is my '66 Falcon and it has them. Even if it didn't, I think it is a good idea.
Re: Vapor Barrier anyone?
if your talking about a charcoal canister then, yes our truck did have them but they were only on A/C cabs, and they were located on the left side of the battery. some 71's and all 72's had a vent on the driver door jamb, this helps air realease out of the cab when you have both windows rolled up and you shut one door while the other is closed.
I don't think they came with a vapor barrier, unless you have a fabric door panel I doubt it would do any good.
http://smg.photobucket.com/albums/v655/aaronhero/ |
My Falcon has a pasteboard door panel with a thinly padded vinyl inner door covering glued to it. My truck (now) has a padded vinyl door covering glued to the metal door panel. The only difference is the substrate, (pasteboard vs. steel door panel) The moisture could still cause the metal door panel to rust from the inside out. Moisture on the back of the padding could probably even allow a musty smell from the wet material.
I replaced the worn out tarpaper moisture barrier on the Falcon with 4 mill plastic sheet. I will probably do the same on old blue. Cheap insurance. |
#5 | ||
"I ain't nobody, dork."
Replace the window wipes and window channel rubber as well.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
All that is new. That will help, but you know that water still gets in there.
Posted via Mobile Device |
Before I put my door panels back on, i am going to put a plastic sheet behind the panel. Just makes sense.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
