Old 10-09-2012, 12:41 PM   #1
afcamaro
afcamaro's Avatar
Recovering Door Panels
What are you guys using as far as glue for your door panels? I am trying to wrap my metal door panels in black vinyl and cant get the vinyl to stick in the small indentions (bead rolled parts) very well with my Loctite spray glue. Thanks, Adam
afcamaro is offline   Reply With Quote
Old 10-09-2012, 02:49 PM   #2
vectorit
What?
vectorit's Avatar
Re: Recovering Door Panels
What year door panel?
In my case with 67/68 door panels, I did not glue to the metal panel. I duplicated what the factory did, and laid thick construction paper with small glue dabs on the corners. Then sprayed 3M upholstery glue onto the paper, then laid felt material, then laid the vinyl on top with a lite dusting of glue. Sprayed the edges, then folded the vinyl over and held in place with box clips.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-09-2012, 03:59 PM   #3
afcamaro
afcamaro's Avatar
Alright thanks, and its for a 70. Do you have any pictures of how yours turned out?
Old 10-09-2012, 04:50 PM   #4
vectorit
What?
vectorit's Avatar
Sure, here are a few.
I cut out the holes last with a razor blade, and used a soldering iron for the screw holes.
Afterwards, there was some irregularities with the finish in the vinyl but they cleared up after time.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 10-09-2012, 05:16 PM   #5
Mayo
Cool Truck
Mayo's Avatar
Those look good, I need to recover mine, thanks for the info.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 10-10-2012, 09:13 PM   #6
Madipie03
Great Job!
Madipie03 is offline   Reply With Quote
Old 11-21-2012, 11:50 PM   #7
dbomb53
dbomb53's Avatar
A little tip for the do it your selfer. A primer gun will work real good, go to home depot or a hardwear store, pick up some glue used for installing formica, (counter tops) it will be a contact cement glue, usually yellow in color. pour into your primer gun, turn the top adjustment screw all the way in. the gun will spay the glue in a misting pattern. spray the door panel then spray the vinle. Stretch it over the panel removing the wrinkles. then spray the back side the same way. No clips to hold the glue to dry will be necessary. once your done with the glue in your spray gun, clean it out with thinner. I've been doing uphostery for a long time, and this works best! Good luck.
"I wanna be like Dino when I grow up"
dbomb53 is offline   Reply With Quote
Old 12-09-2012, 11:08 AM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Great thread.
Great info on the glue, dbomb!
Keith
Convert to disc brakes.
Old 12-09-2012, 12:01 PM   #9
DaHos
DaHos's Avatar
Where is the source for the correct heat press 67-68 vinyl ?????
http://www.smsautofabrics.com/ ??
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 12-09-2012, 05:00 PM   #10
VH Coachworks
VH Coachworks's Avatar
The glue we have used for about the last 30 years is Landau top glue, high heat will not effect it, once it's glued it stays.
Spray both parts, let set till tacky, gets tacky very fast, put together and make sure you have it in the right place or you might not be able to move it.
If you are putting a padding under your door upholstery closed cell vinyl foam
as used in vinyl tops works very well. 1/8 or 1/4 inch it comes 60 inches wide.
As far as a glue gun,there is one made just for this job, it is adjustable and very accurate to apply the glue, once you get good with it you won't even have to mask anything off.
Some people use an old paint gun, problem with that you get spider webs,
and you will have to tape things off.
Hope this gives you a few ideas.
VH Coachworks is offline   Reply With Quote
