Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-09-2012, 03:58 PM   #1
low&slow
turbo question's
I have a friend who wants to put a turbo on his small block v8. He wants to know if he should build up the bottom end of the motor or the top end?
He isn't looking to build anything too crazy. He wants around 400 hp, but still get decent gas mileage, at least 10 mpg.
His motor is stock right now. He has it completely torn apart and is getting ready to build it. Although he does have a set of heads that have bigger intake and exhaust valves than a normal small block head has.
As for the heads, he is getting about 8:1 compression and wants to know if he shaves his heads, will that increase his compression any at all?
Also he wants to know if he should just leave the heads as they are and get domed pistons? Or shave the heads and get domed pistons?
low&slow is offline   Reply With Quote
Old 10-10-2012, 02:38 AM   #2
BigDan3131
BigDan3131's Avatar
Re: turbo question's
The best source of info is here: http://www.theturboforums.com/smf/index.php Every turbo question you can ask has probably already been answered there.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-11-2012, 09:36 AM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Heads, cam, intake / exhaust flow.... all our regular thoughts go straight out the window when you start forcing air down the throat of a motor. When it's force fed,, why would you need some head capable of flowing 300+cfm at 1 atmospheric pressure when you can create 6 or 7 x the PSI with a simple reprogram of the BOV or twist of a wrench on the wastegate.
Build the bottom end for 600+HP and it should survive 400 forced induction with ease. A QUALITY forged piston is a must here.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-13-2012, 02:22 PM   #4
low&slow
Awesome. I will let him know what you all have to say.
As for a Quality piston, what would you recommend?
Old 10-14-2012, 09:51 AM   #5
Marv D
Marv D's Avatar
SRP is the 'shelf stock' line from JE and is easily a 700+HP piston. They just are ran as 'the most common order' and may not see the extent of tooling a JE does. But Just stay away from the hyper-u-cracked it and ANY form of power adder and the motor will live a lot longer healther life
Old 10-16-2012, 03:43 PM   #6
low&slow
Alright, so as far as pistons, I know there is a lot more to a bottom end. My friend wants to know about cranks and piston rods? What brand would be the best to go through for quality made parts?
Thanks for all the help so far Marv.
Old 10-17-2012, 08:54 AM   #7
Marv D
Marv D's Avatar
I like Scat cranks,, their ductile iron street cranks are decent for a n/a - driver setup, and they offer anything you want up to the $2000 Pro-lightened trick deals tolerant of 1200hp. Scat and Eagle are forged in same offshore foundary (as is 90% of the cranks these days) . Eagle finished there, Scat shiped here for final machining. Howards,,, Crower both reported to come from US foundary... only a few I know if still forged in the US unless you get into the ultra upper end stuff like Bryant etc.. Any more I don't think it matters 'whos' crank, it still needs to go to a competant engine 'builder' to be checked for straightness, journals and cracks. It's amazing the lack of QA these days.
Old 10-31-2012, 09:19 PM   #8
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: turbo question's
Turbonetics, Inc.
http://www.turboneticsinc.com/
Precision Turbo and Engine.
http://www.precisionturbo.net/
Banks Power
http://www.bankspower.com/
Pro Line Racing
http://www.prolineracing.net/
Turbo - Turbocharger - Turbochargers - Jegs
http://www.jegs.com/c/Superchargers-...12019/10002/-1
Turbocharger Kits - Summit Racing
http://www.summitracing.com/search/p...bocharger-kits
East Coast Door Warz Pro Mods, Outlaw 10.5, Outlaw Drag Radial, - YouTube
https://www.youtube.com/watch?v=SV_AClXZ2Xw
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
