Old 10-08-2012, 05:23 PM   #1
rkintn_68
rkintn_68's Avatar
Question Energy Suspension 4" lift 72 GMC
I have a 72 GMC K1500 with the 4 " lift on front and 3 " on back ; Suspension Lift, 4WD, 4.0 in. Front/3.0 in. Rear, Chevy, GMC, K/V-Series Pickup, Kit
I really wish it was like 3 and 3 or 3 and 2 ... Can i take a leaf or two out and would that lower it back down a little ??? Or is that a no, no ?
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD
70 CHEVY C/10 LWB x 2 ----- SOLD
67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN "
Build thread :
http://67-72chevytrucks.com/vboard/s...15#post6826315
rkintn_68 is offline   Reply With Quote
Old 10-10-2012, 03:20 PM   #2
GSP7
GSP7's Avatar
Re: Energy Suspension 4" lift 72 GMC
looks like it higher than 4 inches
Im not a fan of real high lifts either, yours looks pretty good like that though.
Im not familiar with energy leaf springs, google search I couldnt find them , just bushings
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 10-10-2012, 06:43 PM   #3
rpatowers
I know you weren't looking for compliments here, but your truck is beautiful as-is. Real nice!
rpatowers is offline   Reply With Quote
Old 10-10-2012, 06:59 PM   #4
wilkin250r
wilkin250r's Avatar
It's sitting on an angle, so it's difficult judge, but it looks fairly level front to back. Is it not?
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 10-10-2012, 07:41 PM   #5
rkintn_68
rkintn_68's Avatar
The front sits a little higher about one inch ... just like the kit says ...
i would like it better level ... try n to find out if you can take a leaf out
or not ... no bid e , was trying to get an answer ... Thanks for the compliments ... Still got a way to go on it , till complete ...
Build thread :
Old 10-11-2012, 12:55 AM   #6
s_nova69
I would not recomend taking a leaf out to lower it. That will really mess up the handling ability of the spring.
I am wanting to lift a sub just a couple inches as well and it seems the best choice is a new k20 or k30 spring and maybe a 1" block. U could have a spring built with the exact dimensions u want as well. Lots of people have been happy with the soft or easy ride springs up front. They are said to be pretty good ride.
I think a new spring that has 3 leafs like. K20/30 would get u where u want to be height wise.
My .02
Nice pickup. Like the color. Keep us posted on your progress
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 10-11-2012, 01:41 PM   #7
rkintn_68
rkintn_68's Avatar
My .02
Thanks Phil , I kinda thought it was not a good idea ... I probaly
just stay with wat i got for now ... still have to finish inside the cab..
Build thread :
Old 10-11-2012, 01:46 PM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
How many leaf's are in your front pack? If there are 4 or 5, I would remove one or two to try and lower it a bit. The stock set up was only 2 or 3 springs.
Oh, and that's a sweeeet looking truck.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-11-2012, 02:21 PM   #9
Oilbrnr
Oilbrnr's Avatar
Put some zero rates in the rear. ORD has them.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 10-11-2012, 02:43 PM   #10
GSP7
GSP7's Avatar
Had to look thuse up http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Old 11-26-2012, 12:40 AM   #11
Madtrucker
How long has the lift been on? The springs will usually settle after you put some miles on it. Block the rear til the front settles or just put a big block in it
Beautiful truck, hope mine looks that nice.
1968 k10 lwb-swb stepside
1936 chevy truck
1977 corvette
My 68 lwb-swb 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=527176
1972/68 blazer 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=641824
Madtrucker is offline   Reply With Quote
Old 12-07-2012, 02:52 PM   #12
JAA
JAA's Avatar
Nice truck. Are you running a 33?
Jerry
JAA is offline   Reply With Quote
Old 12-07-2012, 06:52 PM   #13
rkintn_68
rkintn_68's Avatar
yes 33 -12.50 and the kit has been on for months but have not been able
to drive her but around the block , it has a steering issue and i put all new
front end parts , tie rods , etc ... still a lot of play or might just decide to run
off the road .. i believe after reading a lot on this forum it is a common thing
for these trucks once jacked up ...i going to try the Dana 60 Crossover Steering and High Steer Kits..
http://offroaddesign.com/catalog/Dana60crossover.htm
another 500.00 in parts ... but someday
she will be finished and run the roads ... thanks for the insight and comps ...
Build thread :
Old 12-07-2012, 07:15 PM   #14
69GWC
Did you check the gear box.? Being so old they get whore out and it might be time for a new box.
Looks like you could fit 35s on there pretty easy, I have a 2.5" lift with 33s.
69GWC is offline   Reply With Quote
Old 12-07-2012, 07:20 PM   #15
rkintn_68
rkintn_68's Avatar
put new gear box twice ... and pitman arm ... new disc rotors everything
was replaced on front end and even rebuilt the steering column ...
and yes plenty of room for 35's
Build thread :
Old 12-08-2012, 03:29 AM   #16
72BOWTIE4X
Put an AGR box in it. My k10 has a 4" & it works great!!
72BOWTIE4X is offline   Reply With Quote
Old 12-08-2012, 03:14 PM   #17
69GWC
What is a AGR box.?
Old 12-09-2012, 11:08 PM   #18
Chevrolado
Chevrolado's Avatar
Im kind with this person.. I think it looks pretty awesome actually. Has an agressive stance. I usually dont go for the lean like that too often, but in this case, it looks pretty rad.
Hopefully you can find some joy in it until you can get a level, shorter, kit..
Dave
- 1977 Chevy K10
- 1997 3000GT
- 2006 Chevy 1500 Z71
Chevrolado is offline   Reply With Quote
