Old 10-09-2012, 07:18 PM   #1
missinfishin10
Amazed Member
missinfishin10's Avatar
Shocks for 4" Drop Leaf Springs
What shocks do you guys suggest I use for my 71 long bed when I install my 4" drop mono leafs and the 1" lowering shackles? Are they different than coil spring shocks? After searching endlessly, I cant find shock re-locators for leafs. Is that going to be an issue?
I am using 3" lowering springs in the front. What about shocks on that end?
I live in the mountains of north GA with a bunch of great curvy roads. I am installing front and rear swaybars. Just want it to handle good for me.
Thanks in advance for your suggestions!
Jeff
71 LWB Fleetside
1950 3100 Original Project!
missinfishin10 is offline   Reply With Quote
Old 10-11-2012, 12:39 AM   #2
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Re: Shocks for 4" Drop Leaf Springs
Some guys have rotated the upper shock mounts from side to side but I just drilled out the rear hole and mounted a new stud to get the shock in a more upright position.
Hard Luck is offline   Reply With Quote
