Old 10-09-2012, 08:30 PM   #1
66chevyjunky
Ball Joint question
Converting my 66 to disc up front with 72 componets...the drop spindles I bought were said to be for 71-72. Ordered new ball joints for 71-72. Does the lower ball joint get pressed into the control arm AND the spindle? Or should it just slide in? The drop spindels are mcgaughys and I tried to look up part number but could not find anything on their website.
66chevyjunky is offline   Reply With Quote
Old 10-09-2012, 08:38 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Ball Joint question
The lower b-joint presses into the control arm, but is a bolt into the spindle. You might check the taper on the b-joint pin,vs the spindle....just to verify that they are the same yr parts. crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-09-2012, 09:29 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
What's the spindle part number?
Keith
Convert to disc brakes.
Old 10-09-2012, 11:05 PM   #4
66chevyjunky
the two numbers on them are 6072L/ 6072R and the other one that is really faded is 29402
Old 10-10-2012, 07:52 AM   #5
lolife99
lolife99's Avatar
Does it look like this?
http://www.azproperformance.com/McGa...173-63176.html
The castings are the same from 60 to 72.
The size of the balljoint joint holes and outer tie rod holes are different.
It's hard to tell what you have,... until you confirm which ball joints and outer tie rods fit.
Keith
