![]() Join Date: Jul 2012
Turn Signal Question
When I pull out my headlight switch, both of my turn signal indicators illuminate. Both of the turn signals work, blink, when commanded, but stay on otherwise. Anybody ever run into this?
All Day Every Day '72 C20 Cheyenne Custom Camper http://67-72chevytrucks.com/vboard/s...d.php?t=549132 |
Old member
More than likely a ground issue. Try seeing if the dash ground is bad are try a jumper wire to ground it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Turn Signal Question
I vote bad ground OR maybe those little cardboard tubes are missing that keeps the gauge lights from shining through the blinker holes.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
i second the cardboard tubes... also id check the rear taillights.. they need to have two screws/bolts in the housing before the lense goes on.. i had a major headache when i only had one in... left blinker made brake lights come on.. headlights pulled out it made blinker work.. all sorts of nonsense...
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
