Old 10-09-2012, 10:38 PM   #1
low82c10
DBW problem
5.3/4l603
what would cause my throttle to not respond while the engine is running?
switched 12v i press throttle and it responds, when it starts i get not throttle
i talked to the guy who did my harness also and i have a hard start issue it wont start till after a few tries. he asked if the check engine light is on or off when i try cranking it over and i told him it turns off. what would cause the computer to loose power?
as far as the throttle i know its the right pedal tac module b/c the guy ran my engine with all my parts and it did indeed start.
i tested to make sure my switched 12v is getting 12v while cranking with a test light and it is, im kinda lost at this point? what would cause this a bad ground maybe i dunno?
low82c10 is offline   Reply With Quote
