i need speakers for my '86
alright what i need to know is what size are the rear cab speakers for these trucks and does any place sell them in the factory size? any other sizes fit? they are oddly shaped, aren't they?
the speakers in my truck work okay but have static, comes on and off and it annoys me. |
Re: i need speakers for my '86
The rear speakers are indeed an odd size, 4x10 from the factory. Replacement, particularly of a higher performance variety is difficult to say the least if you wanted to upgrade.
That said, we on the board are highly fortunate that one of our members has been making a replacement rear corner bracket set that allows you to install a pair of the plentiful and easy to find 6 x 9 speakers in their place, with a minimum of modifications and they look at fit GREAT. Look in the 73-87 parts for sale forum for his thread to see pictures and more information on them
Also with the angled prefab 6x9 boxes (bought almost anywhere) setting on the floor you can still get your seat all the way back and most of the speaker is open to the front.
1979 SWB 350/350
78K & 79C Jimmys
I replaced a mono 4X10 with two 4X6 for the front dash
(just showing size diff) Wally mart had some 4X10 Pioneers on clearance there
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
In my 86 I have:
two 12" subs in a sealed box behind the seat two 6x9's in sealed box's behind the seat situated on each side of the sub box two 4" speakers in the dash amp under the seat the system is very good. no problems with seat belt or subs kicking the seat. I had the same setup in my other 86 pickup too... these trucks are SO EASY to install audio systems in... js Good Luck with yours!
-Samuel "Knowledge Is Power" |
I put a 4" loudspeaker in the center....and two tweters at each corner of the dash in place of the factory 3.5's. Then I put 6" midbass speakers on each door bottom....more to come though.....
Posted via Mobile Device |
I just put some 5.25 in the bottom of my doors... What a hassle that was... I've got power windows and didn't expect all these supports and crap behind there... And then I see trucks with 6x9's in the same spot??? I have no idea how they would have done that unless manual window have a lot more room in the door?
Anyway I put a MTX amp matched with a JL Audio 8" Microsub box behiund the seat and it slams like a 12 |
6x9's are awesome, but most companies also sell brackets that convert 4x10 mounting points into two 4" points.
Also story, I'm about to get a pair of JL 6.5" subs to go under the seat. They sound amazing for how small they are!
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
The 6" midbass speakers at my door bottoms have their own enclosure....they mount on the door but does not protrude into the door shell. I pulled mine from a wrecked '07 Caddy CTS and they are Bose 2-ohm speakers. They sound great when getting pushed hard by a PPI amp!
I personally wouldn't go with that old outdated 4x10 size. There is a reason they're not common anymore. The shape itself doesn't produce the sound quality of more modern sizes so it was done away with.
| Bookmarks |
