Help!! Rear cab mount bushings for 1966 c20
Need some help or a work around....
I can not find bushings for the rear cab mount on my 3/4 longbed stepside. I am told no one makes them. Anybody know if that is true? What have others done? The existing bushings are gone Thanks Posted via Mobile Device Posted via Mobile Device |
Hollister, CA.
![]() Join Date: Sep 2006
Re: Help!! Rear cab mount bushings for 1966 c20
I heard Someone out there re-Vulcanizes them.
Might want to search that option...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
1961 crewcab
the rear cab mount can be re vulcanized, and somewhere I saw a repro.. but there is no rear bushing, the cab mount is the bushing, the top of the mount bolts to the cab metal to metal.
your other option is to buy a set of repro or used 1/2 ton rear frame mounts and a 1/2 ton cab mount kit.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
steelerubber.com
Body Mounting Pads & Fittings [Model & Style Charts] Mount, rear cab to frame. Revulcanization service only for #3838523. Send in your original rebuildable cores, and allow three weeks for service. Series 20 and Series 30 Chevy trucks only. 70-2212-48.....$ 125.90/pr. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Thanks everybody for the help, one of these should work
![]() Posted via Mobile Device |
