10-10-2012, 10:14 AM | #1 |
WIRING PROBLEM? help plz
ok I have had this problem with my 70 since before i bought it, I have been dreading putting it on here cuz i feel dumb that i havent figured it out by now, anyways when I press on my brake pedal my brake lights work obviously... but the pedal also brings my front turn lights on, both with headlights on or off, always does it always super bright. Anyone had this problem before? no keep in mind there was a lil bit of a mess with the trailer wiring/ rear end wiring but me and my dad cleaned it up I believe it isnt a problem with the rear wiring now since i fixed it, but im not sure... help please?
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
10-10-2012, 10:41 AM | #2 |
Re: WIRING PROBLEM? help plz
Sounds like it could be a ground problem. A bad ground will cause weird problems. Try cleaning all your grounds first. Chris
Posted via Mobile Device |
10-10-2012, 11:33 AM | #3 |
that is one thing i will be doing soon, more then likely replace a few of them cuz some are pretty ugly lol
10-10-2012, 12:51 PM | #4 | |
Check to see if the hazard button is pushed in and replace the hazard flasher. Same problem in this thread http://67-72chevytrucks.com/vboard/s...d.php?t=544891
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
10-10-2012, 01:48 PM | #5 |
might i add that the turn signals work like they should they flash and everything with or with out the brakes on, its weird, that link if i read it correctly say the turns dont flash, are we able to post video on the site? if so when i get off work tonight i will go home and give u guys a vid clip
10-10-2012, 02:00 PM | #6 | |
Before you go to the trouble of posting a vid check the hazard button, the front and rear circuits are normally isolated from one another unless the hazards are on (4 way flasher).
10-10-2012, 02:06 PM | #7 |
well i have used the hazards multiple times and the problem has persisted for 5 years or more lol
11-20-2012, 03:33 PM | #8 |
bump, does anyone have any other suggestions? i know the hazard button works, and the flasher seems fine because the turn signal does flash
11-20-2012, 04:07 PM | #9 |
Msgt USAF Ret
Take a close look at the front and rear lights and make sure you aren't seeing the tail lights and the front parking lights. If you had a short between one of the rear brake light wires (yellow or green) and the brown tail light wires then when you applied the brakes the four tail and parking lights would come on as well as the brake lights.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-20-2012, 04:19 PM | #10 |
ok, i will check that but would you think that the side markers would get brighter too? cuz they dont...
11-20-2012, 06:08 PM | #11 | |
Msgt USAF Ret
Those don't change. You would have to apply more voltage to increase the brightness and the voltage is constant unless resistance increases. I.G. Ohms law. Try selecting a left or right turn when you put on the brakes. Do it with the key off and then on. If you are getting front turn signals, and no tail lights just the bright brake lights then the TS switch is what I suspect. You can also disconnect the half moon connector on the steering column and jump the white wire from the brake light switch, to the yellow and green wires, then apply the brakes. If the front lights don't come on then the problem is in the TS switch. The white wire is hot when the brakes are applied so you won't need the key. Be sure you do the jumping on the fuse panel side of the connector and not the steering wheel side.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 11-20-2012 at 06:10 PM. Reason: 5000 posts yahoo |
06-01-2014, 06:49 PM | #12 |
this was my whole problem... if you cant read it it says front brake light adaptor.... i saw it there but thought it belonged... never thought to read it....
06-25-2014, 10:18 PM | #13 |
Where on the truck was that part located?
06-28-2014, 05:09 PM | #14 |
A FRONT brake light adaptor?!?!?!?! I never heard of such!!
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
