Old 10-10-2012, 03:21 PM   #1
bk04z66
Factory Relays/circuit breakers
My 71 2wd has 2 what appear to be relays above the wire harness bulkead connector in the engine bay, the wire harnesses coming out of them are cut and not doing anything, they are for sure original factory parts. I can not find them or their wire colors on the schematic I have. The blazer was originally a straight 6, 3spd manual. Is there a different schematic for the stripper models with dummy lights?
bk04z66 is offline   Reply With Quote
Old 10-10-2012, 05:05 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Factory Relays/circuit breakers
The only two that i can think of are located under the dash, one is horn and the other was TSC.
Did you drop down to the electrical board, they have a colored schematic, makes it real easy to follow
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-10-2012, 08:36 PM   #3
bk04z66
Here is a pic of them. They are above and to the right of the bulkhead connector. I have the schematic off the electrical board. The bulkhead wires are different colors than mine.
Old 10-11-2012, 09:57 AM   #4
jaros44sr
jaros44sr's Avatar
Dunno, but green would be horn, tsc are blue, brown, red, i think. never saw that before. Thats not to say its not factory. Also, tsc may not be on manual trans.
SAFETY FIRST
AS usual, off topic
Jim
Old 10-11-2012, 10:49 AM   #5
bk04z66
I cant figure out what they are for. The horn works without them hooked up. Ill post in the electric board.
