Old 10-10-2012, 10:34 PM   #1
Madipie03
Help with tire/lift fitment q78 tires
Im looking at a set of q78 buckshots for my suburban I just bought. However im not sure what they will require for lift. They are a taller skinnier tire and with the right offset im hoping they will fit. The PO of my 70 k20 burb said hes pretty sure it was a 4" lift he put on it some years ago. Ive gotten mixed readings from measurements as far as hub to fender. Maybe the trucks and burbs were somehow slightly different. I dont think so. When I measure from the center of my front hub to bottom of fender I get 25 3/4 inches. The rear sits almost 2 inches lower than the front from the ground. So it sags and it already has a 2 inch block under the rear. Maybe it was a 4" and is wore out or? If anyone has a 67-72 with simliar size tires or buckshots please post a pic too.! Thanks
Madipie03 is offline   Reply With Quote
Old 10-10-2012, 11:18 PM   #2
Re: Help with tire/lift fitment q78 tires
If you have a 4" lift,they will fit for sure.
Old 10-10-2012, 11:20 PM   #3
Madipie03
Thinking about running them on steel fords, or k2500 rims. So Im sure offest will be fine. I just need to figure out the lift so I can buy them before theyre gone! Thanks for the feedback.
Old 10-11-2012, 01:52 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Good luck, They quit making the old school Buckshots a couple years ago.
I wish they did, cause I need some P's.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-14-2013, 06:14 PM   #5
Madipie03
You can look on fleabay. They have some new ones on there that were mislabeled. They are under blem tires. Brand new tho!
