Old 10-11-2012, 02:04 AM   #1
69SCSS
69SCSS's Avatar
Driveshafts for Long Bed
So I have a longbed, and a 1-piece driveshaft. i remember my '66 and '71 both having carrier bearings. Which models got 1-piece shafts and which got 2-piece? Just wondering since I'm putting my truck back together... which is right?
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 10-11-2012, 02:25 AM   #2
BuiltwithIvy
Re: Driveshafts for Long Bed
I have a 69 longbed with a 2 piece, but if you have a one piece, take it and run with it, I will have to pay to get one built
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 10-11-2012, 04:03 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Driveshafts for Long Bed
If it's a long wheel base and has a properly done 2 peice drive shaft it will last for a long long time. Mine is going on 15 years.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-11-2012, 04:07 AM   #4
Ol69C10
Ol69C10's Avatar
I've got a 69 and am looking to put a 1-piece in. Anyone have apart number or info on how to get one? Where to look? How to change it over?
Ol69C10 is offline   Reply With Quote
Old 10-11-2012, 09:04 AM   #5
bonnieclyde100
when you have a one piece drive shaft on a long bed you have less ground clearance for the shaft and the shaft has to be a lot bigger diameter to go that distance.
bonnieclyde100 is offline   Reply With Quote
Old 10-11-2012, 10:06 AM   #6
Ol69C10
Ol69C10's Avatar
So... It would be better to keep the 2 piece if I drop my truck? I'm also lookin at runnin either a 200r4 or 700r4, that gonna matter at all?
Thoughts?
'69 LWB C10: SB350 .060 over @10:1, Comp280 cam, 2800 stall, TH350, 4.11's.
Want 6/6 static drop.
"If at first you don't succeed, failure may be your style."
Old 10-11-2012, 05:55 PM   #7
bonnieclyde100
not enough i have a 700r4 and still needed a two piece
Old 10-11-2012, 06:08 PM   #8
69SCSS
69SCSS's Avatar
OK really what I wanted to find out is which uses what. I'm gonna guess 2 things, but I may be wrong:
1. Short beds got 1 piece driveshafts, long beds got 2 piece.
2. I have a 1 piece driveshaft because it was lowered 6" by the PO and that's too low for the joint on the Carrier bearing, and didn't know that you can flip the bearing and mount on the top.
I will check with some driveline places and see what they recommend. I'm only dropped 5", but who knows, that might be the cutoff. Dunno. I know that my '02 Silverado is a 1-piece and it's gone 130k. But that's a different setup. Much larger diameter shaft.
My 68 SWB
Al Silveira Music
Old 10-11-2012, 07:14 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: Driveshafts for Long Bed
My 71 is a LWB with 700-R4 under it. I had the 2 peice drive shaft cut and rebalanced for the truck with all new carrier bearing and u-joints installed. Nothing fancy just plain ordinary stuff. Almost 15 years ago. Next spring!
