Old 10-11-2012, 02:54 AM   #1
D_E_Sammis
D_E_Sammis's Avatar
1964 dually
I bought the truck last weekend.I will be posting pix in a few day
D_E_Sammis is offline   Reply With Quote
Old 10-11-2012, 03:41 AM   #2
rcbildr
rcbildr's Avatar
Re: 1964 dually
Congrats!!!! Looking forward to seeing the pics.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 10-11-2012, 07:16 AM   #3
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
Thank you.I am having trouble posting pix. Can someone help please
Old 10-11-2012, 07:39 AM   #4
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
i hope this works.
Old 10-11-2012, 08:05 AM   #5
1963c-10
1963c-10's Avatar
Re: 1964 dually
Welcome to the forum. Great looking truck there.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-15-2012, 10:14 AM   #6
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
Some more pix. There is alot i would like to do to the truck but the more i look at it the more i just want to leave it alone. I think the truck might need a tranny. Any body want to part with a SM465?
Old 10-15-2012, 10:22 AM   #7
1963c-10
1963c-10's Avatar
Re: 1964 dually
Should be a fairly easy trans to find. So many people pulling them for automatics
Old 10-15-2012, 12:17 PM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1964 dually
Id throw a 5speed in there...
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-15-2012, 12:29 PM   #9
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
NV4500 would be awesome. Ever done installed one before? What parts would i need?
Old 10-15-2012, 12:33 PM   #10
padresag
Re: 1964 dually
you would also need the 68 and up bellhousing to put a sm 365 in due to the larger input brg retainer
ron
padresag is offline   Reply With Quote
Old 10-15-2012, 12:41 PM   #11
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
Thank you. The one im looking at now is from a 70 2wd and it comes with the bell housing,clutch,pressure plate and the throw out bearing. What would i need to install the NV4500
Old 10-15-2012, 01:03 PM   #12
padresag
Re: 1964 dually
just $. check with advance adaptors (google)
ron
Old 10-15-2012, 01:07 PM   #13
padresag
Re: 1964 dually
here is one that a friend is installing. it also has the adaptor on the back for a t/c
ron
Old 10-16-2012, 12:21 AM   #14
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
That would be the way to go. Thank you for all of your help. Do you have an more pix or link to your friends truck?
Old 11-14-2012, 03:21 AM   #15
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
So i bought a SM465. It looks like its in really good shape. It is complete. I was just wondering how big of a pain in the ass will it be to put in my 64. Will the bell housing bolt right up and what clutch should i use?
Old 11-14-2012, 12:33 PM   #16
1963c-10
1963c-10's Avatar
Re: 1964 dually
Should be same bellhousing as your 3speed. Clutch would be probably 11"
Old 11-14-2012, 12:50 PM   #17
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
thx i have been doing alot of research. This sight is very helpfull
Old 11-15-2012, 12:31 AM   #18
Captainfab
60-66 Nut
Re: 1964 dually
The SM465 will not bolt up to your bellhousing. This is because the front bearing retainer is a larger diameter than the center hole in the bellhousing. You will need a bellhousing from a '68-'72 truck. I would go with a 12" clutch if your flywheel will accept one. Otherwise a 11" will work.
Old 12-21-2012, 09:11 PM   #19
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
Workin Hard!!
Old 01-22-2013, 03:36 AM   #20
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
A few pix to start off 2013. I installed a new hitch. A pic of me and the wife in the front yard. Me and my dad getting some sand for the patio 120x20 all pavers
Old 01-22-2013, 10:55 AM   #21
jdl71
jdl71's Avatar
Re: 1964 dually
That is awesome to see it working like it was meant to. I'm with you, I'd just leave it alone and use it. Very nice truck. Why do you think you need a new trans? Is it popping out of gear? I'm guessing it's got an SM420 now?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 01-22-2013, 11:29 AM   #22
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
jdl71
I Was not at home when my brother and dad picked the truck from the PO. When i arrived at home a few weeks later the first thing i did was drove it. It works great! The tranny is fine and it starts every time no problem. I have no plans do anything to the truck except drive it. It needs a few things It will pull my 3.5 ton dump trailer loaded with no problems.When i get home in a few weeks i will be changing the oil and looking for new tires. The best truck i have had in years.
Old 01-24-2013, 08:26 AM   #23
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
Can anybody tell me why the E-Brake handel in on the floor and not under the steering wheel
Old 01-24-2013, 10:18 AM   #24
MikeS.
MikeS.'s Avatar
Re: 1964 dually
That's how they did the 1 ton and up trucks. Why GM did I don't know. My C30 motor home is the same way.
That is a great looking truck. Now I have to decide which is better looking, the truck or the wife? I hope you treat them both well.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 01-24-2013, 10:23 AM   #25
D_E_Sammis
D_E_Sammis's Avatar
Re: 1964 dually
Thanks Mike. The truck is awesome and the wife is even better.
