Fuel tank to gauge wiring
I am struggling to find the info on here for this. I apologize if I overlooked it somewhere. Where the fuse panel is labeled fuel gauge the previous owner has a wire running from there to the fuel tank. This is the only wire going to the tank. Shouldn't there be one to the tank and one coming back and shouldn't the wire be going from the fuse panel to the gauge since it says fuel gauge?? Any help would be greatly appreciated.
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! ![]() |
Re: Fuel tank to gauge wiring
One ground off the fuel tank sender And the one brown one from the fuse box is all there is.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I think I need to start from scratch...
I have no brown wire. So, fuel level sender unit gets a ground wire then what? Looking up at the back of the fuel gauge I see a empty peg sticking out. Shouldn't a wire go from there to the fuse box?
The sender has a peg sticking out and that is the wire that goes to the fuse box. Usually just pushes on like your cig lighter. There should be some sort of ground wire that comes from your sender that can go to your frame or such. As far as I know the gauge should get all it's wiring through the printed circuit on the back of your cluster.
Quit if it's not FUN!!!
Hello Joe,
The wire from the fuse block goes directly to the post on the tank sending unit. The sending unit is also grounded. As stated, all the other wiring for the gage itself is part of the dash circuit board. Hope that's clear enough. Good Luck, Toby |
yes the gauge gets its power from the printed circuit board on back of cluster.you have a power wire from the fuse box to the gauge and the you have a ground wire from the gauge to the sending unit in the tank and a ground wire from the sending unit to the chassis. there are actually 3 studs from back of the gauge the bottom one goes to ground 1 of the other 2 goes to fuse box the other goes to sending unit.
Thanks everyone, especially BonnieClyde.
BonnieClyde, I did noticed there was two other studs sticking out making it three studs. So, bottom one to ground other 2 studs, one goes to fuse box (I imagine where it says fuel ga.) then the other to the sending unit. Does it matter which one to what? It would be a bummer to blow myself up ![]() Previous person did a partial re-wire and screwed it all up. Half the gauges don't work. I made sure to knock a few dollars off the price when I saw that. Wiring in my opinion is not the place to just wing it. Next thing you know, half your electronics are fried or worse case a fire.
yes i think it does matter . follow the circuit board to the conector and the one that goes to the pink wire will be the power wire from the fuse.the other i think is tan that goes to sending unit.
check the ground wire from the dash connector it would keep
most of the gauges from working |
This thread should help you out. If you know how to work the site the wiring diagrams are on, you can down load them to your computer. Very nice job the guy did that put them on here. Colored and all, it will help you get it fix very quickly.
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Taking the sending unit wire off and getting 3:00 on the gauge proves that all is well back to the sender. Take the sender wire and touch it to the tank or the sender mount and see if the gauge goes to empty. If it don't then the sender or tank ground is bad. Since you are reading empty then my money is on a bad sending unit. If it reads empty with a full tank then either the float is stuck down or the float is full of gas which is very common with these old trucks.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Got it.
I will give it a shot and see. Thanks a lot! Posted via Mobile Device
#13 |
I have my gauge stuck at 3:00 position how do you make a better ground for the tank/sender? What does the purple wire go or do?
