Old 10-11-2012, 10:00 AM   #1
62lwbc10
55-57cab on a 58?
Hey guys what are teh cab differences between the 55-57 cab and the 58 cab? Will a 55-57 cab work on a 58?
THanks,
MArk
62lwbc10 is offline   Reply With Quote
Old 10-11-2012, 10:03 AM   #2
mrhurt73
Re: 55-57cab on a 58?
body mounts and fender mounts are the same, should bolt right in place.
mrhurt73 is offline   Reply With Quote
Old 10-11-2012, 12:47 PM   #3
jfnar
I think that the hood attaches differently on the 58-59 but I think you can work with it.
jfnar is offline   Reply With Quote
Old 10-11-2012, 05:56 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
The only difference that you need to modify it the hood mounts at the cab.
There are several differences but they don't affect mounting.
dwcsr is offline   Reply With Quote
Old 10-12-2012, 12:28 PM   #5
mrhurt73
forgot about the hood, took pictures to show difference.
the gray firewall is the 58 model bolt hole appear to be 3 1/4" apart
the green firewall is the 56 model bolt hole appear to be 2 1/2" apart
Old 10-12-2012, 03:17 PM   #6
OrrieG
OrrieG's Avatar
You will need to trim the frame rails about 3" and relocate the bumper bracket holes so the fenders and rest of clip will fit. Rad support, crossmember and front spring mounts are the same.
OrrieG is offline   Reply With Quote
Old 10-12-2012, 04:54 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
If your just swapping cabs you don't trim the frame
Old 10-12-2012, 05:04 PM   #8
olskool68
If you don't mind me asking, why are you swapping cabs? I was thinking this exact same thing because of rust in the roof (DUH) and I'm sure I can find a good cab somewhere out here in the desert part of TX. I have a '58 also.
olskool68 is offline   Reply With Quote
Old 10-12-2012, 06:20 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Replacing the roof and inner panel isn't all that hard. Cost is 3 or 4 hundred dollars. If you cab is otherwise good just put on new parts.
Old 10-12-2012, 07:57 PM   #10
OrrieG
OrrieG's Avatar
Correct, I thought he was putting the whole banana on a 58 frame.
