Old 10-11-2012, 12:20 PM   #1
neverwinter
idiot ? - distributor hold do9wn how
i have the weird large circlip thing off but not sure how it goes back on? right nw i have about a 1/4 gap between the distrib body - the widest round part - and the intake manifold. this doesnt seem right but i cant get the distrib to seat anymore. i can get the circlip under the distrib but that seems dumb as the distrib will pull right out?
neverwinter is offline   Reply With Quote
Old 10-11-2012, 12:29 PM   #2
63ChevC10
63ChevC10's Avatar
Re: idiot ? - distributor hold do9wn how
Without knowing what engine you have, it sounds to me like the distributor isn't splined into your oil pump. Have you tried wiggling the rotor back and forth to see if it'll seat all the way?
63ChevC10 is offline   Reply With Quote
Old 10-11-2012, 12:30 PM   #3
jchav62
1962 C-10
jchav62's Avatar
Did you pull the distributor out? The distibutor must sit flush and it will do in only two positions. Pull the cap of a rotate the rotor until the dist. fall flush. It may or may not be 180 off. If it is off, it will back fire the the carb. You'll then be able to install the hold down bracket.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-11-2012, 12:52 PM   #4
neverwinter
got it!
Old 10-11-2012, 01:59 PM   #5
1963c-10
1963c-10's Avatar
The "funny clip" actually goes on top of the dist. Must be a v8, the 6cyl dist isn't anywhere near the intake.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-11-2012, 02:07 PM   #6
awbrown
easiest way to get the dist. back in is to have someone hold it down while you bump the starter ,provided you didnt pull it up out of the splines and rotate it when the hold down was off....
awbrown is offline   Reply With Quote
Old 10-11-2012, 02:29 PM   #7
TopFuel1966
TopFuel1966's Avatar
If the distributor driven gear is engaged with the drive gear on the camshaft but the hold down flange won't go all the way down flush with the manifold surface that means that the end of the driven gear is not engaging with the oil pump drive shaft. It's a 180 degree slotted drive so there's only two ways it will engage. You may need to reach down into the hole with a long screwdriver and adjust the pump shaft so that the little bar in the end of the gear on the distributor will properly engage the slot in the shaft.
TopFuel1966 is offline   Reply With Quote
Old 10-11-2012, 02:30 PM   #8
neverwinter
yep got it sorted!! thanks all very much. now just need to figure out the throttle linkage setup for the new edlebrock and the old 64 rod type setup. any pointers?>
