Air Conditioner Compressor Location - 5.3 in a 55 2nd Series
I would like to get some ideas on what others have done to mount the air conditioner compressor on a 5.3 (LS-1) conversion. I am installing the engine in a 55 2nd series. The engine is from an 04 Tahoe. I'm using the drivers side power steering and alternator mounting from the Tahoe. The compressor hits the motor mounts on the pass side. Pictures or recommendations on mounting or where I can find mounting brackets would be great.
Thanks. |
Re: Air Conditioner Compressor Location - 5.3 in a 55 2nd Series
I got my brackets from these guys. I'm not at the point of mounting them yet but they seem nice enough. It does necessitate using a Sanden compressor.
Kim http://www.kwikperf.com/lsx_ac.html |
I have an compressor mount in the parts section. Check out the link posted to see if it fits.
new allen grove ac bracket part # 135r, for sanden compressor, vortec heads, long pump
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 10-11-2012 at 07:15 PM. |
I made mine but it was trial and error. It's basically an imitation of the kwik bracket. If you can't make it, theirs is actually a good deal.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
Thanks Ogre, but that part is for the small block chevy not the LS engine.
Is there a modification or system I can use on the LS engine where I don't need to install the air conditioner compressor at this time and can install it later? I can use the money other places right now.
i made all my brackets; ac, ps and alt.
i wanted the ac low on the pass side a little industrial looking but it works ![]() ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Last I looked the compressor has it's own belt and tensioner. Just take it off and run the big belt only. Then you can add a sanden bracket and longer belt later.
Your right, I guess I just needed to look.
I also used the Kwik bracket on my 5.3. I put a 5.3 in a 56 sedan and now finishing a 5.3 in my 59 truck. Same motor and bracket but I could only find a pic of the car. It's one long serpentine belt so you might have to get the compressor and bracket taken care of now? Not sure but it will make it easier in the long run.
![]() Posted via Mobile Device
'59 Big Window Fleetside |
holley is making brackets now,, check out their website, I saw them at the lsfest
