Old 10-11-2012, 07:04 PM   #1
Andy4639
Old member
Andy4639's Avatar
Wink Floor shifter
I took the old B&M shifter out of the truck last week and mounted a S-10 blazer shifter in it's place. I got it hooked up with the B&M shifter cable right now but have the blazer cable to use if I can't get it adjusted right. The indicator is off some so I need to get under the truck and adjust it but haven't had time. I have the park solenoid wired to come on when the ignition switch is turned on. I wired through a switch I hid and can turn it off and the truck want come out of park.
Here is some pictures.
I mocked up the cover for it out of cardboard and a peice of leather I had left over from the dash pad so once I get the cable right I'll take it to the upholstery guy and let him do the final job on it.
I can't decide if I want the leather are carpet though.
I also picked these stickers up the other night on E-bay along with a Chevelle steering wheel. The wheel seems to be in good shape with some very minor cracks in it. 3 of them and I feel they aren't even enough to worry about right now so all I'm going to do is scuff it up and paint it RED & silver maybe are just RED!.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
