Vin on frame
I was told that the vin number wasn't stamped on the frame rail pre 1971 on 2wd and 4wd is this true? I'm looking at a 1970 and the body's vin is a 4wd I'm just curious to know if the frame had a vin stamped on it to see if its a real 2wd frame or a conversion. Thanks for the help
Posted via Mobile Device |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Vin on frame
Mine is easy to see on both side of the frame, about even with the door.
I've heard, but have not looked, that the VIN is stamped somewhere around the steering sector as well.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Boosted Member
Re: Vin on frame
I will take a peek this weekend on my trucks. My 72 has it stamped in two spots. I will try to see if it's also stamped in the same spots on my 70 frame.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Re: Vin on frame
Ok cool thanks guys
Re: Vin on frame
I have a 70 shortbed 4X4 and the partial VIN is stamped on the frame. It was there also on the 70 Burb I recently sold and it is on my 71 Blazer 4WD.
The entire VIN is not stamped on the frame just the last several digits of the VIN. Usually found on the top of the driver's side frame between the steering box area and firewall. This isn't going to tell you whether the Blazer was a factory 2 wheel drive. Your VIN will start with a C if it was a 2wd and a K if it was a 4wd. For example, KE181sXXXXXX would be a 4wd V8 Blazer (the 2nd letter "E" a V8, the 4th number"8" denates a Blazer). The XXXXXX would be found stamped on the frame. If it began with a CE it would have been a 2wd V8. CS would be a 2wd 6 cylinder. I have only personally seen a couple 2wd Blazers. The couple that I have seen were originally factory 6 cylinder vehicles by their VIN (CS). If the partial VIN on the frame matches your VIN tag then it would have originally been a 4WD.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 10-12-2012 at 09:15 PM. |
Re: Vin on frame
2wd frames are different from 4wd frames; wider on 2wd ahead of the diff for coil springs (4wd are leaf springs).
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
Re: Vin on frame
I have my 71 2wd stripped down to the bare frame and can't find a vin anywhere on the frame even in the usual places was wondering the same thing.
71 2wd k5 67 Nova |
#8 | |
![]() Join Date: Oct 2006
Re: Vin on frame
There are a few documented cases where the partial frame VIN and the VIN plate on the body didn't always match from the factory because the body and frame got out of sequence on the line. But they were usually only off by one digit. Last edited by 29od1; 10-18-2012 at 04:44 PM. |
![]() Join Date: Feb 2012
Re: Vin on frame
As mentioned above, my 69 has the partial vin stamped on the frame by the steering box.
Re: Vin on frame
Finally found it between tranny crossmember and trailing arm cross member buried under what looks like factory undercoating that is all over the bottom of the tub and it was correct.
71 2wd k5 67 Nova |
