10-11-2012, 08:14 PM | #1 |
Radiator
I Got a nice 4 core radiator out of a 454 i am going to put in my 350 the only problem is the little nipple on the pressure cap neck that connects to the hose to the overflow reservoir is broke off, i still have the piece that broke off is there anyway to fix that? can i braze it back on or something? also since i am going up from a 3 core to a 4 core do i need to get a different shroud? Thanks.
10-11-2012, 08:27 PM | #2 |
Re: Radiator
A rad shop would probably fix that up pretty cheap
1985 C10 2004 Avalanche |
10-11-2012, 08:38 PM | #3 |
Re: Radiator
10-11-2012, 11:14 PM | #4 |
Chevy Enthusiast
Re: Radiator
I think the shroud still work or you can make it work, but i think you will need to get the 4 core hold down. It's a wider one piece panel that covers the whole radiator and you should get the wider bushings for it too.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
