10-11-2012, 08:58 PM | #1 |
proper exhaust for a 5.3
I'm just curious to what all you other 5.3 swappers are running size wise for exhaust? My headers are Hooker block huggers that were a LS1 application with 2" reducers, and I originally figured I'd run 2 1/2 dual pipes with a H pipe, but would like a final opinion on if just 2" would be adequate.
10-11-2012, 10:08 PM | #2 |
Re: proper exhaust for a 5.3
I'm no expert but everything I've seen says the LS engines like large pipes.
I'm planning on running 3" exhaust on my LS-2. Kim |
10-11-2012, 10:31 PM | #3 |
Fabricate till you "puke"
I think I would go 2 1/2" on the system on the 5.3. The headers no doubt, have a 2 1/2 " outlet.....ditch the reducers, & opt for a set of weld rings? Then you just carry the 2 1/2, right off the collectors....(the way I plan to do my swap....dollars still pending) crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-11-2012, 11:04 PM | #4 |
2 1/4" would be fine on a 5.3, Are you sure the reducers are 2"?
10-12-2012, 12:45 AM | #5 |
Collector of Projects
Factory 2010+ Camaro 6.2L LS3 exhaust manifolds have a 2.5" outlet.... I have a set for my 6.0L LQ9 going into my K5 Blazer. I had a set of exhaust flanges cut out of 3/8" steel on a cnc waterjet. The Blazer came to me with 2.25" exhaust with flow masters. Since the mufflers are still good, I will just reduce it at the muffler. I will eventually change them out but not spending the money now....
10-12-2012, 10:23 AM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
I thought most trucks had single exhaust that was 3inches. I would think stock 6.0 would be fine with dual 2-1/2" easy and give it max breath-ability.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-12-2012, 10:40 AM | #7 |
Boosted Member
My 5.3 had a 5" exhaust on it for awhile....(coming off the turbo )
When it was N/A I had stainless JBA shorties, dual 2.5" thru magnaflows. Here's a sound clip
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
10-12-2012, 06:12 PM | #8 |
I sized mine using this chart...
http://www.dynomax.com/assets/2008ca...enginesize.pdf According to that, dual 2.5 exhaust is good to at least 350 hp with turbo mufflers. Most 5.3 engines are somewhere around 300hp.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
10-12-2012, 09:12 PM | #9 |
Yeah I was really surprised that they are only 2", they taper right below the flange, I'll probably just cut them there and weld on some 2 1/2 pipe and reweld some O2 senser bungs I guess.
10-12-2012, 09:41 PM | #10 |
Truck and auto performance nut
I just found that the Hooker exhaust manifolds are also 2.25". Seems small.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-12-2012, 09:45 PM | #11 |
HOLY BIG PICTURE Kurt .... lol
714x4... Is it just the reducer thats small or is the actaul manifold outlet small? Can you just replace the collector? |
10-12-2012, 10:08 PM | #12 |
Its just the reducer, I'll probably just cut it at the taper and weld 2 1/2 on it. The headers are intended for ANY tight fit LS swap application, maybe they just sized them down for that. I just asked because I really didnt want to run 2" pipes.
10-13-2012, 10:30 AM | #13 | |
odd name for a pic size.................thumbnail.
