10-11-2012, 10:42 PM | #1 |
Task Force - Bed Roll End Treatment Photos
I DID do a search and would have thought there would be several threads on this, but found nothing.
I'm positive I don't want to leave the ends open and I'm pretty sure I don't want the lights that go in the tube ends, but maybe there are treatments I've not seen that are worth consideration. I'd love to see pictures of yours or that you've saved. Nothing too radical, I want somewhat traditional but clean looking. |
10-11-2012, 11:24 PM | #2 |
Re: Task Force - Bed Roll End Treatment Photos
I think the Dutch build did something trick with his step side. I would check out Delmo's threads too.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
10-12-2012, 09:20 AM | #3 |
Check out Kabwe's build also.
Kim |
10-12-2012, 09:39 AM | #4 |
Certified Car Nut
Rods57's build Last edited by Kabwe; 10-12-2012 at 12:25 PM. |
10-12-2012, 06:11 PM | #5 | |
I love Bam's end treatment but it is a bit too custom for my truck and besides, I don't have the fab chops to pull it off even if I tried. I want my truck to look BETTER, not screwed up! Anymore photos? I knew a guy once with a TF that not only capped the ends but put a flat piece of sheet plate from the front to the back UNDER the bed roll to seal the "tube" and to provide a place to attach industrial strength Velcro so he could run an old school looking vinyl tonneau without using the screw in snaps. |
10-12-2012, 06:34 PM | #6 |
Certified Car Nut
Well forget you Dan if you don't like my rounded bed corners.lol
You did not say what you thought about the pics I posted of Rod57's bed. Its very neat and simple in design. |
10-12-2012, 07:55 PM | #7 |
10-13-2012, 07:44 AM | #8 |
Check out Stepside Jim's thread also. Flat end plate but extended about an inch.
http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
10-13-2012, 11:53 AM | #9 |
slight bed rail mod, nothing to radical
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-13-2012, 12:01 PM | #10 | |
Ha ha, yeah, I didn't like yours, 'ya hack!
Man, I LOVE yours. They're absolutely perfect with your pancaked hood, shaved drip rails & signals, rounded door corners, etc. Perfect for a custom just not for a rodstoration driver. Plus, man you must be like Kareem - you've got Hall of Fame fab chops and think everyone else does too. When you look up hack in the dictionary there's a picture of me there. I'm just learing how to weld, man. I aspire to be 1/4 as good as you are though. I'd like to come over a see your truck but if I did I'd probably want to come home and throw rocks at mine. Quote:
Yeah, those are much more my speed. Possible tapered a bit more on the bottom. DO you just cut a flat piece of sheet to fit, mig it in and flap disc it to blend, or are there subtleties to the backside of those fill pieces? |
10-13-2012, 12:05 PM | #11 |
Yeah, yeah Ogre. I figured you'd chime in at some point. Excellent for some future searcher looking for inspiration but for me? Riiight. Your truck says, "Ok, first build a COMPLETELY CUSTOM HIGH END BED FOR YOUR TRUCK, then...." lol.
Man, I admire your chops. I wouldn't even have thought of your solution much less try to build it myself. You realize don't you that yours would cost tens of thousands of dollars if someone had a custom fabricator duplicate it? Looks awesome. |
10-13-2012, 08:14 PM | #12 | |
10-13-2012, 08:25 PM | #13 |
Bam,
After typing what I did above about 63Split's bed roll treatment, I went back and looked at yours and I wonder if you don't also have a dead end inside the transition you welded in? Did you do anything to close off the tube where it ends.... maybe 1/2" from the bed side? Or did you drill a weep hole underneath where we can't see? If you did, did you put any kind of rust preventative inside there so it won't weep rust down yor paint later? I'm kinda thinking of the Eastwood stuff they sell to spray inside frame rails. I plan to use it around the cab roof from inside before installing the headliner. |
10-13-2012, 11:08 PM | #14 |
Certified Car Nut
Dan I epoxy primed the bottom of the pieces before I welded them together. taped off about a 1/4 for the edge for welding. I do believe we over think this stuff the factory did not put much thought into it and these trucks lasted 30-40 years. I will be dead and gone before this truck rust again.
10-14-2012, 12:56 AM | #15 | |
True we'll be dead and gone and somebody else will be driving MY truck that I sweated over. There ya go, bumming me out on a Saturday night. |
