Windshield washer pump?
Can someone post a picture of where the windshield wiper fluid pump is located?
I have a 1970 C 20. Thanks. Posted via Mobile Device |
Re: Windshield washer pump?
I've been doing a bit of research (busted out my switch, been looking for a new one) and the pump can usually be found IN with the rest of the motor. If you have what look like 3 vaccuum fittings coming off your wiper motor (left side, facing the motor), then I believe you have a 2-speed w/ pump motor. If I'm wrong, I'm sure someone will correct me..
Old member
Factory water pump for the windsheild is mounted to the wiper motor, white plastic with rubber hoses coming off of it. Under the dash just left of the radio.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Active Member
![]() Join Date: Jul 2007
Here's some pics.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Thanks all. I finally have a free day tomorrow to work on this. I appreciate all the help.
