Old 10-12-2012, 12:48 PM   #1
dmw319
Exclamation Rear Frame pics needed
Anyone have pictures of the rear frame where the rear springs connect to the frame? Theres that crossmember that goes across also.. I am having to do some welding/repair in that area and want something to look at as a template so I know I make it look the way its supposed to. I have a few pics already but the more angles the better. Thanks in advance!
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 10-12-2012, 01:05 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Rear Frame pics needed
Here are a couple from my tear down, looks alot different now
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-12-2012, 01:12 PM   #3
Billett
Billett's Avatar
leaf or coil spring?
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-12-2012, 01:18 PM   #4
69gmcc10
69gmcc10's Avatar
This is what I have, hope it helps.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-12-2012, 02:01 PM   #5
dmw319
thanks guys these help a ton!
Old 10-12-2012, 07:39 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Let me know if there's any other area of the frame you need a pic of. I have my 69 down to bare frame and have all sorts of pictures.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
