Old 10-12-2012, 05:05 PM   #1
69truckin
69truckin's Avatar
can any one help me with these wires?
I have no idea what these connect to they lead to the front of my 69 can some one help me?
69truckin is offline   Reply With Quote
Old 10-12-2012, 05:31 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: can any one help me with these wires?
Doesn't appear to be factory wiring.... add-on trailer lights & brakes maybe. Can you trace them out and see where they come from? Try using a voltmeter or test light to see if they come hot with lights etc.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-12-2012, 05:31 PM   #3
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Looks like a bubbafied trailer harness.
Zoomin is offline   Reply With Quote
Old 10-12-2012, 05:35 PM   #4
cleszkie
cleszkie's Avatar
Those appear to be the wires that used to lead to your external voltage regulator. The voltage regulator would have been mounted on the driver side of the radiator core support. The wires are "jumped", or twisted togther because you are probably running a newer style internally regulated alternator and this is what needs to be done with the factory voltage regulator wiring to make it work.
Scratch what I just said. I see that these wires are in the rear of the truck, so my suggestion is out the window. Probably what the others have suggested.
cleszkie is offline   Reply With Quote
Old 10-12-2012, 05:36 PM   #5
69truckin
69truckin's Avatar
hey stoker the wire leads to the front but is hanging down and not plugged in so im not sure.
Old 10-12-2012, 05:41 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The other ends of all five wires are hanging down, not connected to anything? If so, remove 'em. Whatever it was once for, it wasn't factory wiring, and it's no longer being used for anything.
- Mike -
RIP El Jay
Old 10-12-2012, 07:35 PM   #7
68gmsee
Active Member
68gmsee's Avatar
I agree. Those wires look sorta chewed up anyway and the less clutter the better.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-12-2012, 08:44 PM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: can any one help me with these wires?
From the picture u posted I say trailer lights are they had some big a$$ backup lights mounted in the rear at some point. Back of truck and not hooked up. There not the voltage regulator for sure it doesn't run to the back of the truck.
Just get them out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-12-2012, 10:39 PM   #9
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Well, now that the serious business is out of the way, and better minds have identified these as useless or semi-useless trailer wiring (otherwise known as "P.O. Wiring"), I had this info that some might find helpful:
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 10-15-2012, 11:14 AM   #10
camrycurt
camrycurt's Avatar
LOL!
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 10-15-2012, 01:35 PM   #11
67c10rustbuket
67c10rustbuket's Avatar
Dude I almost spit out my gatorade on my work pc
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-15-2012, 03:38 PM   #12
weever82
weever82's Avatar
Bahahaha! Priceless info right there!
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 10-15-2012, 04:05 PM   #13
rsavage
rsavage's Avatar
Maybe the administrators can make that diagram a sticky for future reference?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-15-2012, 08:38 PM   #14
ole dollor
ole dollor's Avatar
now thats funny......i like it....
ole dollor is offline   Reply With Quote
