10-12-2012, 06:37 PM | #1 |
gdavis SWB Steep
Today, I welded some more on my cab. The fire wall gutter was rusty a little so I got my chair and started cutting and welding and grinding. I look at the cab and can't stop thinking wen will this end. I have so much work yet to do. I have to find or fix the kick panels the vent door will not stay in their tract. Then I have to install my new dash and rocker panel
s inter and outer. Pillar block front and rear both sides. Then I will be eady to start the body work (BONDO) and blocking. maybe before Christmas. I hope. Funds are short so I have to do this as I go. I adopted 2 boys from a drug infested family and they take a lot of time and money anyway God will provide. |
10-12-2012, 06:40 PM | #2 |
Re: gdavis SWB Steep
more pictures of my build.
10-12-2012, 06:49 PM | #3 |
keep up the good work mate
most of us have been thru the same tortuorous process and it seems to go on forever but when you finally get there its well worth it. theres alot of satisfaction in doing it all yourself. i drive mine every day now and the 2 and abit years of hard slog are just a bad memory!!!
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
10-13-2012, 04:49 PM | #4 | |
10-13-2012, 08:22 PM | #5 |
showing real signs of progress
