10-12-2012, 08:29 PM | #1 |
1966 c30 cummins
New here and caint find any info on what may be the better way to go swap cab to my 91 dodge 2wd dually frame that way I have everything already mounted expect cab mounts if I swap jus engine and tranny I feel there is way more work involved... Any input would be great.
Posted via Mobile Device |
10-12-2012, 11:29 PM | #2 |
Re: 1966 c30 cummins
Your 66 cab may not fit the dodge frame well. I would do the motor and trans swap. The 12v cant have that much wiring . I would probably swap rear axles, fuel tanks, and radiators ect. You may have to swap new front springs to the 66 front end to support that beast of a 12v. Just my opinion.
Regards, Mike. Posted via Mobile Device
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135 '62 C10 SWB '03 Express Van 5.3l Dead (parting out and using motor) '99 Silverado 4.8l 5 speed 4wd |
10-13-2012, 12:59 AM | #3 |
60-66 Nut
Somewhere here are a couple pics of a '64-'66 body installed on a 2500 4x4 Dodge chassis and running gear with the Cummins. The owner is a member here, but I don't remember his user name.
10-13-2012, 01:03 AM | #4 |
Hmm... Well maybe the body would fit the frame easier then I had assumed...
10-13-2012, 11:36 AM | #5 |
The 66 has been n my family for about 30 years it belonged to my great grandfather. It was used to haul cattle, corn, and coal. Jus a basic farm truck. It has a sbc and four speed... Thanks for the replies guys :-)
10-13-2012, 07:12 PM | #6 |
I put a '61 Suburban on a '91 Dodge frame
http://67-72chevytrucks.com/vboard/s...d.php?t=526540 < bit of work, but runs and drives, thinks its a Dodge, looks like a Chevy |
10-13-2012, 08:51 PM | #7 |
10-27-2012, 08:01 PM | #8 |
I was thinking of doing the same thing with one of my 66 c30s. I may just do a IB4 cummins swap, &disc brakes, but would love to do just a cab swap to a dodge/cummins or late model chevy 3500. if you find any out about this I would love to know...
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
10-27-2012, 10:24 PM | #9 |
Is that a 1/2 ton frame with a 12v? Have a build thread on this or specs?
10-27-2012, 11:25 PM | #10 |
Yes. I started a build thread a long time ago but havnt done anything with the thread in a long time. It's a slow moving project that only gets tinkered with on weekends. If that.
But the motor and trans mock-up is done. Posted via Mobile Device |
10-27-2012, 11:47 PM | #11 |
Good luck on it and I hope you found a Dana 60 to use in your build as that Cummins will eat the 12 bolt for lunch. Let me know when you get it running and driving!
10-27-2012, 11:48 PM | #12 |
I thought about that and decided that the truck will never see enough traction to eat anything but tires.
