I was told the VIN is under the gas tank but so far I've not found a single '67 ~ '73 with this feature .
Where is it located ? . Cab and frame locations with pictures please . TIA , ![]()
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
![]() Join Date: Jan 2012
Re: VIN Location ?
3 places i know of are the spid on the glove box door, theres a vin plate on the drivers door jamb under the striker bar (the thing your door latches to when its closed), and on the drivers side on the frame but from what iv heard you cant get to it or very easily at least when the truck is assembled, iv never heard of one being where you mentioned unless maybe the vin was on a build sheet left behind by the workers
Re: VIN Location ?
On the driver's door jam, on the SPID like this:
![]() and on the top of the frame on the driver's side between the steering box area and the firewall there will be a partial VIN that will match the end of your VIN if the frame matches the cab. The stamping is clearly visible if you clean and sand the paint off the top of the frame.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Old Skool Club
![]() Join Date: Jun 2001
Re: VIN Location ?
Okay, I found 4 locations on my truck. One was on the SPID on the inside of the glove box door; second one was the VIN tag on the cab, in the drivers door opening; the third and fourth are not complete VIN's, but are the numbers which begin with the letter denoting the factory where it was built. Both of those numbers are on the drivers side frame rail. One of them is beneath the cab, while the other is in front of the firewall. Next time I am at my sons' house, I'll take pix so you can see what I mean. My truck is below: It says "9S812417". It is a '69 that was built in St. Louis and it is the 12417th for that year. Kinda funny, tho. Everything I found on my truck that was dated, is all from September of '68; seat belts are dated as is the block. I don't have the original intake or carburetor, so I can't say for those. I wish I had the build sheet, but I don't. Best I can tell, my truck was built the third week of September, 1968. For the VIN to say it was the 12,417th one is making me wonder how many of whatever body style was built on that line. Oh, all vehicles built at St. Louis for '68, have VIN's starting with the numeral "8".
Those of you who have done a body-off will already know.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 10-13-2012 at 06:42 PM. |
