85 with 305 starting trouble
Now have been having this for some time. Have replace coil 2 time mod once rebuilt carb Choke is in open possion not hook up. It will start some time and run ok. Then may not start for a day or 2 try each day then try next day start. Any guess?
Also does any body make any of the engine part no longer at dealer? |
Re: 85 with 305 starting trouble
fuel pump? collapsed line?
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
This is simple but have you checked the spark plugs?
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
Yesterday try to start on second time it turn over started. Pull a trailer with lawn mower 3 mile mow grass for 2 hours load back up started on second turn again. Each time just turn key not touch gas peddle. Two day ago turn key turn over a lot ,push gas turn over some more push gas again no started. I let it sit for about 2 hours try again same thing no start. I put plug wires dis cap on about a year ago may need to check them.
What does EFE stand for on smog decal under hood? |
Dude, seriously, I can barely understand what's going on in your posts. If you want people to answer you, then you probably should structure your sentences a little better......but I'm guessing you're doing this on a phone...
Anyway, almost everytime I had a starting issue it was related to the coil button. Try that...good luck
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
78K & 79C Jimmys
how open is the choke?
do you pump the gas at all when starting? cold carbs need 2-3 shots before it will have enough to fire cold
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
| Bookmarks |
