Old 10-13-2012, 06:57 PM   #1
JRANGER
JRANGER's Avatar
Replaced Carb no brakes?????
I replaced my carb and now my brakes dont work...Hooked everyhing up like the last carb, brake booster is connected to the brake vacuum and t in a pcv valve....Not sure why but thats how it was on the other carb and when they didnt work i put it back that way...
ANy ideas? There is fluid in the brake booster....but they worked before and now they dont...I cant stop the truck unless i mash them all the way down and it doesnt really stop all the way
JRANGER is offline   Reply With Quote
Old 10-13-2012, 07:51 PM   #2
clinebarger
Re: Replaced Carb no brakes?????
With the engine running....Physically check for vacuum at the booster check valve.
clinebarger is offline   Reply With Quote
Old 10-13-2012, 08:00 PM   #3
tucsonjwt
x2 on obvious vacuum issue. Odd story, when I replaced my booster check valve the brakes worked fine for about 5 miles, then the extra proper pressure blew the vacuum booster If you need a new booster, I recommend an OEM Delco rebuild - from online discount OEM GM vendors - about $120 as I recall, about twice that for a new Delco booster. This is one place where I think OEM makes sense.
tucsonjwt is offline   Reply With Quote
Old 10-13-2012, 08:04 PM   #4
Square_78
Square_78's Avatar
I fixed a bunch of vacuum leaks on my Edelbrock carb and my drum brakes suddenly worked better than before!!
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 10-13-2012, 08:47 PM   #5
bilfman
bilfman's Avatar
Honestly doesnt sound carb related, I think that it may just be a fluke that it occured after the carb change. It is the "to the floor" that make me suspect another issue, vacuum is an assist so you dont have to power mash the pedal. I would check your hoses and lines for a leak and if that does not yield any fruit try bleeding them.
I assume that you have unhooked the booster vac line when running and put your finger on it to see if there is vacuum there?? If not, disconnect it from the booster and run the engine, check with your finger to see if there is any vacuum.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 10-13-2012, 09:11 PM   #6
JRANGER
JRANGER's Avatar
ahh WTF the power/brake connection has not suction...But the pcv valve connection on front does....Am i missing something here? On my old carb it was all connected to the PCV valve connection as their wasnt a brake booster connection
Old 10-13-2012, 09:39 PM   #7
clinebarger
Clogged vacuum line, Bad check valve??
Old 10-13-2012, 09:41 PM   #8
JRANGER
JRANGER's Avatar
NO i checked i direct at the vacuum valve..... and this Street Avenger is brand new..
Old 10-13-2012, 09:51 PM   #9
clinebarger
Old 10-13-2012, 09:52 PM   #10
JRANGER
JRANGER's Avatar
yeah i dont know lol....
Old 10-13-2012, 10:12 PM   #11
68Timber
I know the pieces fit
68Timber's Avatar
The little 90 degree plastic elbow inbetween the booster and large vacuum line is pretty easy to crack. The get old and brittle, you may have cracked it. Ask me how I know.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-13-2012, 10:15 PM   #12
JRANGER
JRANGER's Avatar
There is no vacuum at the valve on the carb...... The PCV has vacuum though....Just not the brake booster valve
Old 10-13-2012, 10:21 PM   #13
68Timber
68Timber's Avatar
I missed that. The master cylinder may have pushed though.
*edit* I just read closer about the vacuum problem. I don't know, I've obviously already thrown out the two things that have happened to me that resulted in a similar sounding brake failure. But that's a new one to me.
John
74 Honda Z50 build
Old 10-13-2012, 10:47 PM   #14
INSIDIOUS '86
INSIDIOUS '86's Avatar
The one way valve isn't backwards is it?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-13-2012, 11:21 PM   #15
bilfman
bilfman's Avatar
The port may be plugged by the carb gasket. But in your case I would just pull vacuum off the intake, there are several ports on it. Some may be used , some plugged. Just tap into one with the proper fitting and leave the carb out of it if it is giving you grief.
Old 10-13-2012, 11:23 PM   #16
bilfman
bilfman's Avatar
I just re-read your post, just tap into the pcv line and dont use the other. Easier then the intake solution.
Also just to test if that is the brake issue, and you dont have a 'T' fitting, hook up the booster to the front vac and see if the brakes work.
Old 10-13-2012, 11:30 PM   #17
hatzie
Moderator
hatzie's Avatar
I've seen gaskets block that rear port. I'd cap it if you don't use it. I had a few G20 vans with the brakes tapped off a port behind the carb into the manifold.
The fleet's all diesel now so it's been a while.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-14-2012, 12:04 AM   #18
JMac11
JMac11's Avatar
Make sure the port is not plugged on th NEW Carb. Installed a new Holly once, no vacuum. There was a port plug inside the vacuum port on rear of "universal carb" not all vehicle have power brakes and they did not send them out with a rubber plug on them, back in the day.....
JMac11 is offline   Reply With Quote
Old 10-14-2012, 11:52 AM   #19
JRANGER
JRANGER's Avatar
Im not sure whats up with the port but its not being used now....Im wondering if maybe the diagram for my carb was wrong...As it didnt show another vacuum line on the back of the carb even on it... Eitherway i removed the plug from the back and hooked the brakes up to it and its all working now
Thanks guys
Old 10-14-2012, 03:12 PM   #20
byeoficr
you may not have enough vacuum to run both you might want to run the booster off of a manifold port an see what happens. incidentally do you hear vacuum noise inside the cab when you step on the brake? if so you need a new booster
byeoficr is offline   Reply With Quote
Old 10-14-2012, 09:31 PM   #21
JRANGER
JRANGER's Avatar
everything seems to be A-OK right now...
