10-13-2012, 10:46 PM | #1 |
Grandpa in the rustmobile...
Can someone ID this disc crossmember..
Was told its 71 72 anyone confirm this?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-14-2012, 12:00 AM | #2 |
A guy with a truck
Re: Can someone ID this disc crossmember..
Judging by the steel bushed arms and disc spindles, if its all original, I'd say yes, it's 71-72
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-14-2012, 07:12 PM | #3 |
My rear axle from backing plate-backing plate is 56"
Do I have the wide rearend? truck is a 69 or 70 Im not sure how to tell..... Going to look for axles if its the wider of the 2. Will any 71-87 5 lug axle slide in if its indeed the wide rear?
10-14-2012, 08:12 PM | #4 |
A guy with a truck
I think that's the wider version. Check wheel mounting surface--it should be 63.5". If so, later 5-lugs will swap right in...
10-14-2012, 09:49 PM | #5 |
Looks like a 71-72 to me also
Posted via Mobile Device |
10-15-2012, 12:48 AM | #6 |
So take the wheels off and check drum-to-drum?
I'll do it in the AM would be nice if it was the wide version... 71-87 axle? or just 7172
10-15-2012, 12:57 AM | #7 |
Who makes the best/cheapest drop spindle 2.5"
http://www.performanceonline.com/71-...e-2-half-inch/ http://www.earlyclassic.com/catalog.aspx http://www.summitracing.com/search/Y...=drop+spindles I liked ECE but for the extra $25..... Also I can find a few other things for front suspension via summit bushings shocks and maybe replacement Bj's and suspension parts (if they carry moog or similar)
