Old 10-14-2012, 01:42 PM   #1
alyslo
Cool Installing big block in a 64 k30
Looks like I have to slightly modify the firewall in order to do this conversion. Does anyone have any pictures or thoughts on how to do this and make it look somewhat normal? Its a 454 with nv4500 transmission conversion. I have a front crossmember/engine mount out of a 67 4x4. Any ideas would be greatly appreciated. Thanks!
alyslo is offline   Reply With Quote
Old 10-14-2012, 02:57 PM   #2
padresag
Re: Installing big block in a 64 k30
here is one going into a 65 2 wheel (eng mounts in the same place). he didn't have to modify the firewall. you may have to just slide that c/member forward a hair. just put it in place and see what it looks like. that cross member rests on the inside of the frame so should support it without bolting it up for that
https://picasaweb.google.com/fritz19...42660038055314
ron
padresag is offline   Reply With Quote
Old 10-14-2012, 04:06 PM   #3
RockTonka
RockTonka's Avatar
We modified the firewall for valve cover (tall) clearance in our 2wd 66. Large cap HEI still had plenty of room. Most people don't notice it, seems obvious to us though
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 10-14-2012, 07:14 PM   #4
66farmer
66farmer's Avatar
I modified the fire wall just a little bit.
66farmer is offline   Reply With Quote
Old 10-15-2012, 01:18 AM   #5
Captainfab
60-66 Nut
I would just slide the engine forward a couple inches, and not have to modify the firewall. You will have to run the short water pump if you do. That is what I did with my '66 Suburban.
Old 10-15-2012, 02:57 AM   #6
argonaut
argonaut's Avatar
I second that. Since you aren't running a stock 4-speed with the bellhousing crossmember it should be easy for you to just slide the whole thing forward.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-15-2012, 01:13 PM   #7
1963c-10
1963c-10's Avatar
Rocktonka....what wire looms did you use to route the wires down the valve covers. They give it a very clean look.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-15-2012, 09:10 PM   #8
alyslo
Thanks for all the pics and info guys!
Old 10-15-2012, 09:43 PM   #9
RockTonka
RockTonka's Avatar
I forget the brand, but you can get a feel for the look in the pics. These were designed to be mounted in a horizontal orientation off of the outer valve cover bolts...wasn't possible with the valve covers we liked. We flattened the mounting tabs and made some adapters that allowed them to sit vertically on the opposite side they were designed for.
My build thread
Old 10-16-2012, 12:55 AM   #10
Captainfab
60-66 Nut
Those look like the R&M Specialties wire looms. I've used them several times. Good quality and good people to deal with. You can also buy them at Summit.
http://www.rmspecialties.com/
Old 10-16-2012, 08:48 AM   #11
1963c-10
1963c-10's Avatar
Thanks to both of you. They just look real clean...i like it.
Old 11-17-2012, 02:56 PM   #12
alyslo
Looks good! What did you use for headders?
