Old 10-14-2012, 04:48 PM   #1
watkins boyz
help please on my 1964 1 ton panel truck
is there anyway i can update the front end and rear end power steering. disc brakes 5 lug . lower? hellllllllllp
watkins boyz is offline   Reply With Quote
Old 10-15-2012, 01:01 AM   #2
Captainfab
60-66 Nut
Re: help please on my 1964 1 ton panel truck
It's pretty much the same as upgrading a C10 or C20. The main difference with your C30 is that I believe it should have leaf springs in the rear. That will make it easy to swap in a '73-'87 10 or 12 bolt. Take a look here for a bunch of info on the front suspension and brakes.
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
There are a few more listed in the '60-'66 FAQ thread at the top of the page.
Old 10-15-2012, 10:47 PM   #3
watkins boyz
are the frame rails the same if i wanted to go with one of scotts hotrods bolt in crossmember?
Old 10-16-2012, 01:06 AM   #4
Captainfab
60-66 Nut
Yes the frame is the same in the front suspension area. Your frame may be a little different farther back since it is a C30. But then again it's been a while since I have looked under a 1 ton panel.
