Old 10-14-2012, 06:26 PM   #1
JGross
Advice on Vortech 5.3 swap
I'm doing the preliminary research into the issues with swaping a Vortech 5.3L into my 65. I'm worndering if i'll have to modify the frame at all? anyone know?
JGross is offline   Reply With Quote
Old 10-14-2012, 06:37 PM   #2
66C06
66C06's Avatar
Re: Advice on Vortech 5.3 swap
you shouldn't have to modify the frame. You may have to use the hot rod swap or ls1 oil pan and motor mount adapters, but other than that you should be good. Corvette C5 manifolds and many other ls car manifolds should fit without hitting the frame...
66C06 is offline   Reply With Quote
Old 10-14-2012, 06:59 PM   #3
Shooters_7
No frame modifications need to be done. You will have to relocate the a/c compressor if you plan to keep it. Not a big deal and you can get a set of headers from one of the vendors on here that fit really well.
Shooters_7 is offline   Reply With Quote
Old 10-14-2012, 09:39 PM   #4
SchnorrCS
I'm thinking of doing this too. Any good threads or websites that cover it?
SchnorrCS is offline   Reply With Quote
Old 10-15-2012, 01:42 AM   #5
Captainfab
60-66 Nut
Lots of info to be found here......
http://www.67-72chevytrucks.com/vboa...ysprune=&f=206
Old 10-15-2012, 09:07 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I put a 4.8/4l60e in my 65 and no, no frame mods need to be done, as long as you will have the high mount AC ( if you have AC). I used POL perches and mount plates from Summit ( I think). trans cross member from CPP and Sanderson Shortie headers ( CSLS1).
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-15-2012, 10:07 AM   #7
TopFuel1966
TopFuel1966's Avatar
You can run the A/C compressor in the factory location. You just need to use a 90 degree connector block and ECE motor mounts.
TopFuel1966 is offline   Reply With Quote
Old 10-15-2012, 12:19 PM   #8
Clyde65
Clyde65's Avatar
Topfuel1966, that is what I did, but I trimmed about 1/2" or so of frame just for good measure. I also use the doc's blocks for the connections but, I guess those are not offered any longer.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-15-2012, 02:28 PM   #9
65Gregg
65Gregg's Avatar
I think Captainfab needs to start selling the mounting plates for LS swaps to add to his line of fine products.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 10-15-2012, 06:25 PM   #10
b.eddy's72
b.eddy's72's Avatar
I second that. Im going to need them for my 72 hopefully in the near future.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 10-15-2012, 07:03 PM   #11
bryankichler
bryankichler's Avatar
I think headers will play a big part in what needs to be done with the frame. I dont recommend fbody headers on this truck they are a pain in the arse. Wish I had spent the extra bucks on good headers.
bryankichler is offline   Reply With Quote
Old 10-16-2012, 12:46 AM   #12
Captainfab
60-66 Nut
I tried that and it took me almost a year to sell one set.
