Old 10-15-2012, 01:44 PM   #1
|ow|ife
|ow|ife's Avatar
Automatic to Manual conversion on 4wd
Hey guys,
So my next potential project is a 4wd 75 1/2 ton. The current owner says the stock auto trans (which he's unsure of type, guessing a TH400 though) is slipping between 1st and 2nd.
Motor wise, it's got a 400.
**If I were to get this project I would want to swap in a manual trans just out of personal preference.
>>>My question is this: What (if any) factory 3 or 4 speeds can work with the 4wd transfer case? I'm *guessing* it's a divorced-style tcase given the age, but am not sure. I was told by one person a Muncie 4speed would work but would relish some more discussion and insight on the topic, as well as any builder experience.
Thanks in advance!
it's not what you buy, it's what you build
use your skills, not your wallet
|ow|ife is offline   Reply With Quote
Old 10-15-2012, 05:29 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Automatic to Manual conversion on 4wd
GM used transfer cases that bolted to the back of the transmission. The SM465 4 speed and NP205 transfer case is the correct combination for a manual transmission truck.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 10-16-2012, 07:44 PM   #3
liftlawssuck
liftlawssuck's Avatar
^^^ Agreed^^^
liftlawssuck is offline   Reply With Quote
Old 10-16-2012, 08:38 PM   #4
Redcap
I concur. And the SM465/NP205 is a really tough combination.
Redcap is offline   Reply With Quote
Old 10-16-2012, 08:52 PM   #5
x ReAcT x
x2
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 10-18-2012, 01:26 PM   #6
|ow|ife
|ow|ife's Avatar
ooookay then! Commit this knowledge to the mental archives; thanks guys!
The truck I was looking at got sold but there are always squares coming up for sale so when there's one that's just right I still want to do this conversion and in the mean time, I know what to start eyeballing at swap meets or trading friends for.
Thanks!
Old 10-18-2012, 03:04 PM   #7
Redcap
Thanks!
Look for a hydraulic clutch too. Nice feature to have.
Old 10-26-2012, 05:24 PM   #8
mickman1977
I swapped a TH350/NP203 for an NV 4500/NP 205 setup. Love the overdrive for the highway and the hydraulic clutch. Got the 4500 out of a 92(?) 1/2 ton (yes, 1/2 ton) and the 205 out of an 86 1 ton. Made a spacer 2.5" thick and bolted them together. Works slick as a whistle. Just be sure to get your yoke angles right after the swap or else you'll be pulling your hair out figuring out vibration issues. (been there, done that)
mickman1977 is offline   Reply With Quote
