Rear Coil Springs
Has anyone found a rear coil spring to replace the original ones that is softer. Mine rides like a brick and i think if I think a softer spring in the rear would soften it up a bit. Maybe something that can be found at the junk yard from a car with the same type of rear suspension??? it would need to be the stock height or a little taller.
69 Chevy ProStreet, Low and wild. 78 Corvette rturnpaugh@compcams.com |
Livin' it up.
![]() Join Date: Nov 2001
well if you want taller then your probably SOL because that would indicate a larger and tougher spring for most intensive purposes.
If your springs are old and saggin' and worn then it'll ride pretty rough.. get some new springs and shocks... you'd be suprised at the difference it can make. On my 3/4 the ride got much better just from shocks.. i'm putting new springs in currently but the truck isn't moving at the moment
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
![]() Join Date: Mar 2001
I know when I was researching springs for replacing my stock
height C-10 shortbed....Could find anything in the MOOG line except Heavy Duty springs for the rear. I found TRW sells a variable-rate spring....not sure if they will soften the ride. The should be a bit softer until the truck is loaded down. You dont happen to have an extra stiff shock installed do you?
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
its all about the +6 inches
I wouldn't be suprised if you have the heavy duty springs in there...or HD shocks, these things ride quite nice.
The springs are pretty heavy duty. I should probably check out what is on some of the trucks at the junk yard and see if I have something HD or not.
Thanks for the info.
I figured it out. I had too much air in the rear tires. This sounds stupid, but with these tires I had 20 psi and that was just too much. I dropped it down to 15 psi and it's as smooth at babies...
These are Sportsman 31x16.5x15. Thanks for the info.
Be carefull...remember the Ford Explorers all blowing out tires and flipping over?
That was partially due to the socker moms complaining of a harsh ride, so Ford told them to deflate to a certian PSI...without contacting the tire guys. |
