10-15-2012, 05:17 PM | #1 |
55-59 SBC Motor mounts
Hey everyone, I am new to the forum. Some of you may recognize me from the HAMB.
I am planning on taking my 57 GMC off the 4x4 K5 Chassis and stick it back on to an original chassis that I sourced. First off what motor mounts do you all suggest for a small block Chevy?? Also what else do you think I should do to prep the frame other than the normal stuff, brakes, replacing wear items and doing upgrades. |
10-15-2012, 07:13 PM | #2 |
Re: 55-59 SBC Motor mounts
A little more information on what your plans are will help. Are you keeping the stock suspension or upgrading with the front and/or back? What engine and tranny are you going to use? There are a couple of new guys talking about putting their TF trucks on a K series frame, maybe you can do a trade!
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
10-15-2012, 07:26 PM | #3 |
I would be more than willing to sell this frame off to someone after I'm finished. Its got a bit of a kink in it though.
This truck is and will stay my daily driver My plans are as follows: mid 60s styled hot rod truck, its already bright blue drivetrain- 350/350 combo platter It has already been converted to 5 lug all the way around 62 impala rear axle, will get disc brakes in the front front suspension will have 3 leaves removed and possibly a drop axle rear suspension will possibly get a mono leaf or I will make new drop shackles, both if I put the drop axle in the front basically the same height as terd fergusion eventually this is how she sits now plus a little pin striping and no big dumb exhaust tips |
10-15-2012, 11:17 PM | #4 |
Interesting, I know a few rednecks around here that would kill for that truck the way it sits.
On the mounts. 350/350 you will want to go with one of the tube crossmebers that runs under the pan and uses stock type Chevy side mounts. If you run the stock front mounts that bolt to the front of the block and the front crossmember you end up putting too much stress on the bellhousing area of the trans and run the risk of having front seal and other issues. That sounds like a fun project, keep us posted on the progress. |
10-15-2012, 11:23 PM | #5 |
Yeah I know of more than a few red necks around here that love it more than their mamma. its pretty funny watching them gawk
10-16-2012, 12:01 AM | #6 |
Expect some PO'd rednecks when you change it over then. Some of those guys can't understand why anyone would lower a truck "cuz ya can't take it huntin".
10-16-2012, 12:22 AM | #7 | |
10-16-2012, 11:38 AM | #8 |
Over the past 40 years I've seen a couple of transmissions with broken ears on the bellhousings that were attributed to the car or truck having front engine mounts and an automatic with the rear trans mount. With the converter bolted to the flex plate and a slight flexing movement in the bellhousing area it can cause issues with the seal over time.
10-16-2012, 12:26 PM | #9 | |
10-16-2012, 03:19 PM | #10 |
I'm using the stock front mounts on my truck but if I had it to do over I would use side mounts. It seems that most later model accessories like the p/s pump, and/or most of the serpentine belt drive systems use the same bolt holes that the front mounts use.
BTW, Cakes, that's a sharp looking truck but I understand why you want to convert it back. I like the look, but those straight axle 4X4's don't drive all that good. |
10-16-2012, 07:56 PM | #11 |
Depends on where you want to drive them!
10-17-2012, 12:18 PM | #12 |
Like I said before, This is my daily, it sees mostly highway and street driving. Maybe the occasional dirt road on the family farm but thats what the tractor and the kawi mule are for
