Old 10-15-2012, 10:08 PM   #1
hath
Longbed to shortbed conversion
Is it possible to just move the axel and its components forward to accomodate a shortbed and then simply cut the excess frame off? I'm asking this to avoid taking a long bed and cutting it up to look like a short bed.
hath is offline   Reply With Quote
Old 10-15-2012, 10:13 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Longbed to shortbed conversion
Nope. Gotta take something like 12 inches out between the cab and axle...sorry.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-15-2012, 10:34 PM   #3
SS Tim
SS Tim's Avatar
Much as I hate saying it if you must cut a truck down the frame cut under the cab (at an angle) seems to be the best route. The wheelbase comes down 12" The bed looses 12" off the front and another 8.14 off the back. Lots of cuttting and welding. On my project I'm planning on using a wood floor so things might get a little easier. There are threads on shortening here that are very useful for reference. We even hashed the concept of bobbing the rear first to get a feel for everything before deciding to do the box front and frame.
SS Tim is offline   Reply With Quote
Old 10-15-2012, 10:41 PM   #4
SS Tim
SS Tim's Avatar
On the chance that I misread the question. A LWB frame can be altered to fit a factory short bed box. It still needs to be cut from the middle and have body mounts moved in addition to cutting off the rear. This is due to the drop center frame rail shape and crossmembers. Having a short box to match up would be a huge time saver and really help assure success.
Old 10-16-2012, 01:54 AM   #5
chevy88
chevy88's Avatar
Here is how I did mine but do a search there is few ideas on how to do this..
http://67-72chevytrucks.com/vboard/s...d.php?t=371381
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
