10-16-2012, 12:07 AM | #1 |
700r4 mounting question
So I installed a 502/700r4 in my 63 shortie shop truck and I had a tube trans crossmember from a different project so I bolted up everything so my question is I leveled the motor/trans combo off the carb mounting flange but end of trans seems high but everything clears is that right ?
///Relaxed Atmosphere |
10-16-2012, 07:04 PM | #2 |
It's Better With Nitro
Re: 700r4 mounting question
You'll just have to pay attention to the pinion angle of your rearend...which you would need to do anyway with a drivetrain swap.
10-17-2012, 12:17 AM | #3 |
60-66 Nut
The trans output shaft and the pinion need to be on the same plane. Otherwise you can have driveshaft vibration issues.
10-17-2012, 01:00 AM | #4 |
i understand about pinion angles , which is not what i was asking about
its in relation to mounting the trans crossmember , im not using a bolt in one cause i stock floored my frame Posted via Mobile Device
10-17-2012, 11:08 AM | #5 | ||
10-17-2012, 06:46 PM | #6 | |
